Question about Sharp Microwave Ovens
Have a sharp carosole r-2a46 microwave was working great .. had cleaned it now the time just blinks and cant get it to work . help please
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Plate does not rotate freely and make noice
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: i cant ste the time on my sharp r244 microwave
Contact Sharp UK support at http://sharp.co.uk
Posted on May 28, 2010
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Door of sharp microwave will not open
    Take it back, if this becomes a problem then you will have a harder time getting customer satisfaction.
    Jul 09, 2012 | Sharp R-930AK Convection/Microwave Oven
    I cant ste the time on my sharp r244 microwave 1800watts ,can u help please dee
    May 27, 2010 | Sharp Microwave Ovens
    LCD not working on microwave
    The is a prone problem accross the Sharp range where the LCD fails. They can be repaired but this can be quite costly.
    Feb 17, 2010 | Sharp R-370E 1000 Watts Microwave Oven
    Sharp carousel model number R-930ak + parts The plate inside does not spin sounds like a cheap plastic gear on the bottom is worn out and stripped. MAkes a clicking sound
    This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
    http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
    For the model number you have listed, the part number is 46-841666-3.
    You can purchase replacement parts at searspartsdirect.com.
    The site also offers helpful exploded view diagrams to assist you in parts location/identification. The motor is listed at item 001-20 under the "Cabinet" heading. If you have any questions, please post back and let me know. I hope this helps you.
    NOTE: You also consider the turn table coupling, which is item 004-22. The underside of the coupling has a keyed slot that fits on to the turn table motor shaft. If the coupling becomes cracked, or if the keyed slot "rounds out", it may be slipping on the motor shaft and not turning.
    Dec 17, 2009 | Sharp R-930AK Convection/Microwave Oven
    Sharp R1505 Microwave
    when you press for the time you want does it come up on yhe display?? if not clean the circuit board with wd40, & retry dont go two fast when operating as this can lead to the machine not to respond. also check the pad give it a clean and a good dry,
    Apr 07, 2009 | Jenn-Air JMV8208A Microwave Oven
    Sharp microwave LCD is garbled, but microwave still works
    We repair those for US and Canadian customers, and occasionally we'll have an Australian customer, but the extra postage is usually prohibitive.
    We not only repair them, but we install proprietary upgrades designed to prevent it from failing again.
    If you're interested, f
    eel free to contact me directly (and please remind me of your full model number) for more information & help.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    Jan 18, 2009 | Sharp R-308J Microwave Oven
    Nov 27, 2008 | Sharp R-1480 Microwave Oven
    My microwave sharp 220hw 8oowatt
    After snubbing the darned thing overnight, plug it back it to see if it has recovered. These things do have primitive computers and we all know how reliable those things are- It may just have 'crashed,' just like seemingly all others.
    Nov 05, 2008 | Sharp R-220HW Microwave Oven
    Microwave Ovens Logo
    57 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
