Question about E-Machines (T2958) PC Desktop
Desktop recovery disc for laptop
I have an emachines desktop and laptop. Both had Windows XP. I wanted to format and reinstall on the laptop, but, on the second disc, there was a scratch, so it did not work. Since my laptop was formatted, I tried using the Desktop Emachine recovery disc. Windows installed and everything seems to be working fine, except that, when I open network connections, the only network icon is the 1394 Net Adapter. Neither the LAN nor the wireless network icon show up, and I obviously am not able to connect either with an ethernet cord or through a wireless network. How do I get them to come out of hiding?
  • 7 more comments
  • rabbi56 Feb 20, 2009
    It is a Gateway 8510 Laptop, with Windows XP Home. Since the recovery disc for the laptop was damaged, and i only realized that it was damaged after I started the reinstall, which formatted the hard drive, and left me with nothing, I used the one that I had for my emachines desktop - which also has Windows XP.
    I can't find a serial number the barcode says that the Model is 8510GZ, and the P/N is IPA200000258. under that, there is a string of numbers and letter BNBW5230658
    The main problem is that in dsevice managers, under network adapters, the only thing that shows up is the 1394 Network adapter, and nothing else
    The full model is 8510 GZ
    There is nothing with a yellow exclamation point. Under "Other Devices" there are severeal things with a yellow question mark, including "Ethernet Controller" "Network Controller" and others.
    Can I save it to another computer, then transfer it to a disc, then load it to my computer? if not, how can I get it to the laptop?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    are there any letters after the 8510? SHould be like a gh or hh or something like that.
  • RescueTechLA
    RescueTechLA May 11, 2010
    First place to check is the device manager. Have you got anything with a yellow exclamation point?
  • Ben Wabnick
    I think it would better for me to look it up by the serial number. Whats the serial number?
  • Ben Wabnick
    Are you trying to install the drivers on your desktop or laptop? Also what Operating System are you trying to install for?
    Also please verify the model of your desktop or laptop.
    Thanks.
    President:
  • 2,653 Answers
Yes, you can do that. I usually just download either the wireless driver or the wired driver ONLY and then once that's up and running I just use the computer to get the rest. Usually I'll just do a "Windows Update" and see what it pulls down as far as drivers go and then whatever is left just download to complete.
That should do the trick!
Posted on Feb 20, 2009
  • 2,404 Answers
Courtesy of Gateway here is your driver for the network card:
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=11417&os=10406&type=10095
Now here is where it gets tricky. I'm not sure what wireless network card you have there but on that page is a section that says other available downloadsm click on where it says "click here to view these results". There will be drivers for different network cards. I believe it will be the first one in the list, the broadcom one, if not then try any of the other wireless card drivers. Hope this helps you and sorry for the delay.
  • Ben Wabnick
    Ben Wabnick Feb 20, 2009
    save it to a flash drive, those tiny drives that hook up to a usb port.
  • Ben Wabnick
    then bring it over and copy the files to the desktop
My emahine e725 is froze onreovery magement
Looks like you will have to reinstall windows, unless you have a recovery disc.
If you have the original Windows disc you can reinstall windows.
If you want to keep all your old vids and pics, just put the disc in the drive , then restart your pc, make sure its set to boot from disc drive.
install windows on the same place it is now DONT format the drive if you want to keep stuff, if not format it. if you dont format it will put all your current files into a folder called Windows.old after you get a fress install go to C: and look for windows.old
Jul 11, 2012 | eMachines E620-5885 Notebook
Can i format my HD on an external bases with my laptop, then install it back into my pc. my hard drive crashed and i need to get it to boot. i dont have the boot disk
Technically, YES, the hard drive can be formatted as an external (with the appropriate equipment) on your laptop (if there are still files on it, you may even be able to extract them from it) but it still won't be bootable because it does not have an operating system on it.
That would be the part where you need the recovery disc. Windows setup programs from these boot discs already have the format utility so if there aren't any files to extract from the drive, you can skip to reinstalling Windows on the desktop and formatting it in the process.
Bottom line is that you need a Windows installation disc to make the hard drive bootable again, regardless of where you format it.
Aug 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
I have a emachine desktop W3115. It lost the network adapter and does not recognize the internet. I bought a OPERATING SYSTEM DISC Dual Core Windows XP Media Center Edition but that did not fix the network...
If you still have the original eMachine software as your desktop, go to Start > system Recovery > Create my Drivers and Application CD disk.
This will create a CD that will contaon all the drivers for your eMachine.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | eMachines W3115 PC Desktop
Can't find my startup disc for my emachine, is
yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
May 23, 2011 | E-Machines eMachines Desktop PC
How to downgrade from windows 7 to xp on emachine laptop
If it is a new emachine, then it proberly will not let you. There is a problem with drivers. certain pieces of the hardware might no have any drivers that are supported by XP.. The best thing you can do is check the emachine website to see if any drivers XP. If so then follow this basic guide to format and re-install XP on your PC.
http://simontodd.com/2010/02/how-to-format-a-pc-and-reinstall-windows/
Thanks
Mar 01, 2010 | E-Machines eMachines Desktop PC
Is there a system recovery disk for the emachine ET1161-07 desktop pc?
If you bought the computer new and did not receive a recovery disc with it then the recovery software can be reinstalled from a hidden drive built into the computer.
The steps for re-installation:
  • Restart the computer
  • When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  • When prompted with a boot screen, hit the Enter key.
  • After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If you bought the computer used try the above method. If that fails then it came with a recovery disc but you didn't get it with the computer. The only thing you can do is contact eMachines support for help or purchase a new copy of Windows and reinstall it with that.
I hope this helps. If not and you need any help with reinstalling a new version of windows please let me know.
Oct 22, 2009 | eMachines ET1161-07 Desktop PC
Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Sep 26, 2009 | E-Machines eMachines Desktop PC
Remove the emachine/PC ANGEL RECOVERY SOFTWARE
PC angel isn't installed as such it uses the desktop.ini to load its software.
desktop.ini is used to by windows to customise the view of individal folders in windows.
if you know how go to command prompt
type in;
attrib -h -r -s -a c:\folder\*.* /d /s
( replace c:\folder with the drive/folder of the protected folder )
next type in
del c:\folder\desktop.ini
( Again replace c:\folder with the drive/folder of the protected folder)
Bye bye protection for that folder
Apr 14, 2009 | E-Machines (T2824) PC Desktop
E system desktop pc
You should have them from your first install that should work, if not some emachines have a recovery section on the hard drive already that should allow you to re install your WinXP OS at least to factory origanal any time you want to Hope that is of some help to you. Thank you
Aug 03, 2008 | E-Machines eMachines Desktop PC
Emachine failure. no recovery disc.
just go to www.newegg.com and purchase an OEM copy of Windows XP for 99 bucks. thats your best bet. Or you may have a recovery partition on that desktop...if you press f11 when you turn it on it may let you recover from that. good luck
Jul 29, 2008 | E-Machines eMachines Desktop PC
E-Machines (T2958) PC Desktop Logo
252 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
