Question about AT&T 1480 Phone
At&t 1480 2.4 ghz new call light keeps flashing
The new call light on my at&t 1480 2.4 ghz phone won't stop flashing. the display shows 1 new call and 00 old calls. I can't find the owners manual
    President:
  • 2,992 Answers
You can download the manual here. Just scroll down 'til you get to your model.
Posted on Apr 09, 2009
Why does ot keep flashing with a green light
The phones led light will flash green when you have a new message or a missed call. After reading the new message/missed call, the flashing will stop. hope this helps
May 03, 2014 | Doro Phone Easy
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Indicator light won't stop flashing
I have a Uniden 5.8 GHz and the message indicator light will not stop flashing. The phone screen says I have a voice mail but I don't. Does anyone know to fix it?
Feb 04, 2010 | Uniden 5.8GHz Cordless Phone
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
I have a GE 2.4 GHz Model No. 27831FE1-D and the
What I did was to unplug thr phone line first, then I disconnected the power supply from the base and lastly, I took the battery out of the handset and left everything disconnected for 24 hours and when I reconnected it up, the blinking stopped. I hope this can be of assistance to someone using this phone or others having the same problem. Milt Gloria, in excelsis Deo
Jul 06, 2009 | Thomson Lands Phones
The in use light is on, All phones are turned off.
Did you recently replace you old phones with these phones? Maybe the old handset of the phones are interfering with them...remove batteries from old handsets, as they may be searching.
Apr 18, 2009 | AT&T 650530003417 Cordless Phone
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    "new voice mail" display
    call your phone service and have them disconnect the voice mail and if they cant just remove that have them set there rings at like 9 since most phones only have up to 5 rings for the machine to answer.you will have to use there voice mail service to hear your message and then delete it but should be good after that. i have comcast and they said it would take 3 days to deactivate voice mail but told me how to get there so i can get rid of that flashing light, hope this helps you
    Oct 28, 2007 | GE 25942GE2 Cordless Phone System
    Power went off last night and our phone stopped working
    I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
    Apr 14, 2007 | Uniden CLX485 Cordless Phone
    AT&T 1480 Phone Logo
    343 people viewed this question
    Top AT&T Lands Phones Experts
    george  peters
    george peters
    Paul C.
    Level 1 Expert
    Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
