Question about Insignia IS-DVD1001 DVD Recorder/VCR
I put the disc in and then it closes and then opens again and i close it and it opens again. does it need to be cleaned or what?
    President:
  • 1,223 Answers
Itis unable to load the disc from tray to the spinning mechanism for playing or recording take it to the repairs there is an assembly problem or loading mechanism problem
Posted on Feb 20, 2009
3 Suggested Answers
SOURCE: durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Posted on Aug 24, 2007
SOURCE: Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Posted on Jul 08, 2009
Flashing green lights on console, tray opens on it's own, hit close button and it does but then opens again a few seconds later.
u need to put a disc in if u r playing it and then close and do u have it standing up or laying down coz if u have it up it will open so u need to have it laying down and if it still opens u need to take it apart and get rid of the fluff from the xbox coz thats whats happened to me and since i cleaned it it shuts
Sep 29, 2013 | Microsoft Xbox 360 Console
My xbox 360 will not read the disks i put into it. it is like it isn't reading that there is a disk in in the tray. it says open tray then close tray over and over again. it wont spin the disk to read it.
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
Got a xbox 360 and i put a game in then it tells me to open tray so i open then close then tells me to open again and it just keep doing that i cant play anything
Dec 24, 2010 | Microsoft Xbox 360 Console
I put the disk in close close the tray and it says open tray what do i do
Dec 23, 2010 | Microsoft Xbox 360 Console
PS3 Won't Take Disc!
Hi, I think it was me who had helped you before. I will be glad to help again. Ok, first you have to tear apart your PS3 (just like when you cleaned it). Now looking at the rollers and "dogs" make sure that they are closed and not open all the way like when a disc is in it. Look at the flap on the top too make sure it opens and closes freely. Next, PLEASE BE CAREFUL!! Plug your PS3 in and try to hit the eject button, if it is reset and ready for a disc it will beep twice when you hit the eject button without a disc in it. Place the top back on the he DVD drive and try to insert a disc. At this point it should take it. If not then try hitting the eject again. Once the PS3 resets and takes and ejects discs again, then you can put it back together.
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
DISC DRIVE KEEP OPENING
open our drie n u shuld ee a white bar at the front bottom of the drive just move it bak n forth a couple of timesthen put it back together n see if it works
Mar 23, 2009 | Microsoft Xbox 360 Console
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Mar 03, 2008 | Audio Players & Recorders
Durabrand pdv-702
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Insignia IS-DVD1001 DVD Recorder/VCR Logo
89 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
