I whant to replace the display on my NEC Multisync 1980sx monitor
Display Part # LTM190E1-LO4 Samsung, Where would I search to locate the replacment display?
    Genius:
  • 2,120 Answers
EBay
Posted on Feb 20, 2009
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
An 'etch-a-sketch' - type image that at quick glance, looks like an elephant, appears in the upper right section of the screen. It isn't captured with print screen. Swapped out monitors to different CPUs....
I did see a similar issue with a Gateway display, the source of the image was the screen is damaged by the cover inside the screen. Basically, the inside frame was scratching the back of the screen making the image to appear until it damages the screen enough to turn off pixels.
Another possible cause are: "burned pixels", some kind of damage (liquids inside the display), the display was hit, or something like that.
The only solution is to replace the display or use it until is breaks (but it will be quite annoying).
Mar 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
-5004: Ox80029c4a error. Have lost my NEC display monitor. Tried to install latest nVidia driver for my NEC Multisync LCD1970GX monitor. Driver did not fully install, and now I can't install a copy of the...
Error Code: -5004 : 0x80041f42
Error Information:
*C:\Program Files\Common Files\InstallShield\Professional\RunTime\11\50\Intel32\iKernel.dll
>inc\CoCreate.cpp (44)
>SetupDLL\SetupDLL.cpp (1405)
pAPP:Realtek High Definition Audio Driver
PVENDOR:Realtek Semiconductor Corp.
Oct 15, 2009 | Samsung HL-P6163W 61" TV
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 22, 2007 | NEC 1560V+ 15" Flat Panel LCD Monitor
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
