Question about Philips 55PP9352 55" Projection Television
Red power light on chirping beeping sound
Red power light on no picture,no sound just a chirping sound
    Genius:
  • 1,139 Answers
Hello miko_alexand,
That problem indicates that the Horizontal Output Transistor (HOT)is beginning to malfunction. I would suggest that if you have a background in electronics that you do the following:
1) unplug and open the back of the set
2) look for the HOT and locate the Collector, Base and Emitter of the transistor and using your multimeter set to read resistance measure from the collector to the ground, it should read high almost infinite, red from base to ground it should read low and from emitter to ground it should read low.
3) if the HOT when read from the collector to ground reads low then you can bet that the HOT has a short circuit from collector to ground, and will have to be replaced.
4) In addition I would also perform a ring test on the Integrated High Voltage Transformer (IHVT).
This will tell you if the IHVT has suffered any damage from the HOT malfunctioning. You may end up having to replace both of the components.
If you do not have a background in electronics I would suggest that you take the TV to your local TV repair facility.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 20, 2009
  • Henry McKelvey
    Henry McKelvey Feb 20, 2009
    I would also suggest that you check the ribbon connectors from the deflection board to the signal board, some times the ribbon cables go bad, and create this problem.
Is it normal for a garrison smoke detector to have a flashing red light ?
Yes in normal operation the red light should flash intermittently every 30-40 seconds.this lets you know the battery has sufficient power for detecting smoke.when the battery needs replacing the unit should beep/ chirp in singular sound every 60-90.if smoke I'd detected the difference is very obvious as the shrill beep is continuous and much louder.
Feb 19, 2015 | Home
Sanyo dp26671 hdtv no picture or sound but have red light
If the power light is flashing, it could be excessive or shorted voltage or that the capacitors are malfunctioning. In this case, replacement capacitors or a new power board is in order. Contact a professional for help.
If you hear a chirping sound, that is the shutdown circuit activating, indicating a problem with the power supply.
For more tips and tricks, check out No picture on TV for troubleshooting steps and solutions. I hope this helps!
Sep 28, 2012 | Sanyo Televison & Video
Philips 55PP9352 Rear Projection, no picture or sound
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Nov 16, 2008 | Philips 43PP9202 43" Rear Projection...
Won't turn on...
first Trun up the screen, is you see vertical colapse IS because you not ertical Drive..
Jul 26, 2008 | Zenith R50W46 50" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
No Sound or Picture, Chirping Noise coming from back
There are many other fuses on this board you need to check them all. May need a schematic.
Dec 03, 2007 | Philips 51PW9363 51" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
