Question about Whirlpool LER5636P Electric Dryer
Dryer will not run all cycles. It shuts off after a couple of minutes. Must hold or "jimmie" the cycle knob for it to run.
  • 686 Answers
Change the cyle timer
Posted on Mar 02, 2009
I have a gas dryer. It heats up just fine, but it won't shut off. if put on time dry it won't count down the time and on any other cycle it will just keep running and drying
Oh I can't think of the name of it right now but the whole knob assembly inside needs to be replaced. It's like a timer its integrated into the knob.
Jan 05, 2015 | Dryers
Why is my frigidaire dryer quitting after running a few minutes. It runs fine on the no heat so the motor is alright.
Not neccessarily the cool cycle uses less power and pressure from the motor, the winedings on motor may be bad or going out? does it shut down after 20-30 minutes of running? u may also want to check ur venting and ur thermostats the cycling and the thermal cut off, if ur having an over heating problem they can and will shut off the cycle as a safety precaution
Jun 22, 2014 | Frigidaire Electric Dryer
Can anyone assist with this problem - the power goes on but no buttons work at all. They either beep fast or shut the entire dryer off. Also, the setting light on the main knob is always blinking now...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
My Kenmore Elite will only run if I hold down the Start button. Will I need to replace the Start button? Also, the end of cycle Signal sound continues even after I open the dryer and runs until the...
heatman101
Nov 10, 2010 | Dryers
When I turn the cycle control knob it no longer makes a noise
heatman101
fg
May 30, 2010 | LG DLG7188 Gas Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
