Question about Philips Magnavox DVD/VCR Dual Player
I get sound recording but no video when using my magnavox dvd rec
I can't see what i have recorded with my magnavox zc320mw8 dvd recoder. I think i my have it hooked up wrong but no longer have the wiring diagram. can anyone help me please?
  • 8,596 Answers
You have to use a red, white, and yellow connection, or a red, white and s-video connection.
Two possibilities:
1) Connect a yellow composite A/V cable (or an S-video cable, if you prefer) from the video or monitor OUT of your cable or satellite box.
OR:
2) Connect a yellow composite A/V cable (or an S-video cable, if you prefer) from the video or monitor OUT of your TV (many TV's don't have such a thing).
Try recording again - it should work this time.
-Tha Mp3 Doctor
Posted on Feb 20, 2009
Codes for a magnavox dvd recorder zc320mw8
The applicable code would be in a compatible remote.
Mar 19, 2017 | Magnavox Televison & Video
I have a Magnavox ZC320MW8 DVD recorder. I am having a devil of a time gettng it to finalize DVDs. What do I need to do?
This I believe will come down to software. The DVDs are all copy protected but by no means is it high security. I would check into some firmware update or additional software to download on to the recorder to open and finalize.
Jan 21, 2013 | Magnavox ZC320MW8 Multi-Format...
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
I forget the exact steps for the remote to record from my video camera to dvd recorder
You have to plug the video cam into the front ports of the Magnavox.
Then press the Setup Button
Go to Required Settings --> OK
Video Input --> OK
Go to E2 --> make sure it says "video in," unless you are using an S-Video connector --> OK
Press Setup
Start playing from Camcorder and make sure that you can see the picture on your TV screen.
Press REC on the Magnavox
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Philips Magnavox DVD/VCR Dual Player Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
