Question about Kenmore 62602 Electric Dryer
Kenmore Dryer louder sounding now when running
I have a Kenmore 600 Series Dryer.
It has all of a sudden started sounding loud.
Any ideas on what could be causing this problem?
  • 28 Answers
Sounds like your bearing is going out
Posted on Feb 20, 2009
I turned on the Kenmore 600 dryer and a loud grinding sound was heard and it wouldn't start - what's the issue
Mine is doing the same thing. Tomorrow if it is sunny and warmer I will take some photos and post em to you.
Jan 09, 2011 | Kenmore 600 6965 Electric Dryer
I have a Kenmore 80 series dryer. When we start the dryer the unit gets a loud noise it will run through a few loads but then the noise will get louder then the dryer will cutoff.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 20, 2010 | Dryers
Kenmore 90 Series Dryer started to operate very loudly. The noise sounds like it normally does while drying, just much, much louder than usual.
I would think the belts are getting bad need to be checked anyway, also while your checking the belts check the tenision pulley for the belts make sure it has not fallen off, also, make sure dryer is LEVEL, hope this helps let me know please thks larry
Feb 27, 2010 | Kenmore Dryers
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
Repeat banging noise in dryer
Sounds as if the drum supports are bad. Replace the rollers that the drum glides on and should be good to go.
Feb 01, 2010 | Kenmore Dryers
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
Have a constant noise when dryer is running. Best description of the noise sound is, it is a similiar sound like the washing machine is in agitation mode....any ideas what the problem might be??
your felt pads front and rear are worn out these dryers do not use bearings instead they use a strip of felt for the drum to ride on replace these and the noise will go away
Apr 27, 2009 | Kenmore Dryers
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
172 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
