Question about HP PSC 2175 All-In-One InkJet Printer
Same as other people ... wants to re align every time and paper jam ... then says align cartridges but obviously they are aligned cause it still prints ok but it will not scan anything and print it out either ... only print out from what i have on my computer or the internet ...
    Genius:
  • 2,120 Answers
Replace all cartridges with Genuine HP carts
You are low on ink. The message will not go away until you do it.
Posted on Feb 20, 2009
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
I have alignment issues with my lexmark x4690, the rollers thread the paper in at diff. times and causes a jam. how can I fix this?
Leading cause of paper jams and misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 26, 2012 | Lexmark X4690 Wireless InkJet Printer
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
My HP Officejet 5615 All-in -One shows "Papierstau" (paper jam) though there is no sheet or piece of paper in it.It then also sometimes shows first "aligning cartriges" and then "paper jam" and then...
Unplug your printer. Then wait 40 seconds and plug it back in. Check if you have enough ink in your cartridges.
If all else fails replace ink cartridges.
They make paper that has alcohol on them and you can run it through your printer to clean those sensors. Just hit Cltrl and P at the same time.
May 18, 2017 | HP Officejet 5615...
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
HP PSC 1400 all in one:
Some things to try...
Open the printer as though you were going to remove the cartridges.
Pull the paper that is in the tray out of the tray. Ensure you do not have too much paper for your particular tray to handle.
Look inside the printer to ensure there is no obvious paper jam. Close the printer. Give it a second or two to think....
Put the paper back into the paper tray. May just need a smaller pile of paper. If there is too much paper in your tray it will not go through the rollers properly.
If lights are still blinking after that however read any messages follow instructions if poss. Sometimes you just need to hit the enter button at this point to clear. Cartridges may align any point (hopefully).
If none of this works. Look for a "Toolbox" or something in your printer/scanner software on your computer that would enable you to send the align printer cartridges command from the software. That may align them as well.
I would be interested to know if this works. Good luck!
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
