Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2100 bag full indicator light on with new bag, power shuts off
  • cbcbass Apr 07, 2009
    I have the same issue. I have had it looked at by two seperate vacuum service shops and both said the same thing. The switch assembly is defective and the part cannot be gotten from electrolux. I am still looking for the part.
  • 134 Answers
HI
sounds like the hose is blocked. Drop a coin throgh it to check
Posted on Feb 20, 2009
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux 2100 does not turn on. the light bag full comes on even with a new bag
The bag might not be seated properly or you are using the wrong type bag.Try reseating the bag.
Jan 20, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
412 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
