Question about JVC AV-27530 27" TV
How do I get the dialogue removed from my TV screen?
The dialogue remains on my TV screen - how do I remove it?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would appear that the 'Closed Caption' has been enabled in your TV. This can de disabled in the MENU/Settings. A more detailed procedure would be available in the owner's manual or pls post back to confirm if your TV is a JVC AV-27530.
Good luck and thank you for using FixYa.
Posted on Feb 24, 2009
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
When playing a DVD, I get the dialogue printed on the bottom. How do I turn this off?
Goto the DVD movie main Menu look for Close Captioning turn it off.Will have no more dialogue printed on the screen bottom.
Mar 14, 2011 | Element Electronics FLX3210 32 in. LCD TV
Can't close dialogue box
Sounds like a virus spyware issue. If not try to download the norton removal tool. you can download it from symantec.com
May 31, 2010 | Toshiba Satellite A135 Notebook
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Apr 09, 2010 | Toshiba 57H84 57" Rear Projection...
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Printed dialogue on TV screen
THat is Closed Captioning, and you can **** it off by pressing the menu button for your tv, and finding the option CLOSED CAOPTION (OR CCD) (or CC) and set it to off.
There may also be a CC or CCD button on your remote that if you hit it a few times it may turn this off also.
It will be either in the menu, or a button on the remote.
Jun 14, 2009 | Televison & Video
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Tevion 19 LCD TV Model Number 1961HDT
these come with 3 year warrenty ... ring their helpdes in uk 087 663 1540
May 02, 2008 | Televison & Video
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
JVC AV-27530 27" TV Logo
100 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
