Question about Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
I can print from Tray 1 but I would like to print checks
from Tray 2 on Ricoh Aficio 1013F. I have tried to change the priority tray on the machine but it hasn'rt worked. On the software I have it doesn't allow an option of tray 2.
Thanks for you help
Nadine
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Posted on Feb 20, 2009
My aficio 1013f can not scan a4 but only b5
CHECK THE PAPER SENSOR, U CAN SEE ON THE RONT OF TRAY COLOR GREEN AND SELECT THE RIGH PAPER SIZE RICH FOR U
Jan 17, 2014 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F MFP bottom tray paper senser broke off. Where can I get a replacment?
Remove the actuator and try using super glue or adapted a little part of ABS.
Feb 16, 2013 | Ricoh Aficio 1013F Copier
RICOH Aficio 1013F coping
Check if your copier has DUPLEX unit installed, the Duplex unit is a optional component for copiers, seems that you don't have that option installed.
Feb 15, 2010 | Ricoh Aficio 1013F Copier
How to set factory default at Ricoh Aficio 1013F
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Jan 04, 2010 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
I have option to buy ricoh 1013F copier i need it to be wireless
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
Hope this helps,
TankMurdock
Apr 23, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
How do I stop information page from printing out?
(Reports on/off)-Key operator tools,user parameter,switch03,bits 0 and 5 set to 0.That should do it.
Jun 17, 2008 | Ricoh Aficio 1013F Copier
Ricoh 1013f with optional 2nd tray
You have to set it through the menu button, just scroll through the options.
Dec 21, 2007 | Ricoh Aficio 1013F Copier
273 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
