Question about Dryers
WON'T START MY DRYER QUIT WORKING, SO MY HUSBAND TOOK OFF THE BACK AND THE START SWITCH LOOKED BURNED OUT SO WE BOUGHT A NEW ONE AND INSTALLED IT AND IT STILL WON'T WORK, BUT IS GETTING JUICE?? IS THERE A RESET SWITCH?
  • 28 Answers
Two hot red and black 110 volts each, 2 grounds, 1 installed in the middle screw and one to the body chasis in a mobile home after removing the copper bridge, standard home has only 1 ground and needs to use the copper bridge from the middle screw or ground and the body chasis, if your getting juice, TURN OFF THE POWER, Then tighten all 3 screws inside your pigtail plug to make sure your getting a good connection. Rob
Posted on Feb 20, 2009
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Wiring problem. Won't turn over. Can't get wiring right. Suzuki quad runner 250 1999. Had some toggle switches. Rectifier burn up. Bought new one
start looking for a full harness fo replace it with thats just a mess and will only lead to problems down the road
Jan 30, 2013 | ATVs
Dryer won't start, light is off, but fuse is ok
Had a similar situation after running the dryer for multiple loads. I checked the wiring schematic and found the overload thermal switch location on the exhaust duct. Using my $4 volt amp meter I checked and found the circuit open (the switch open circuit). Removed the switch, went to the appliance parts store and bought a replacement for an exorbinant $9. Installed the switch and it has worked for the past couple of years.
Now that was my solution. You will need to check the wiring diagram for the problem. I would not buy a new dryer just yet until looking for a simple switch or contact that isn't working.
Dec 20, 2012 | Whirlpool LEB6300 Electric Dryer
Dryer not working
becky843,
Huuum,at your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems.
if they are not serious, or they are a temp glitch!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Sep 17, 2008 | Kenmore Elite HE4 Electric Dryer
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire Affinity Dryer
try hitting stop clear twice check the door switch see if its working also if you didnt send in your warrenty card then frigidaire dont know when you bought it if youve never had it serviced i was a factory tech for years for frigidaire so you can call them and say you bought it say a week from now and get it serviced let me know what happens
May 17, 2008 | Dryers
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
