Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Can't get two screen option off tv
My Sony Trinitron, model KV-22XBR55, TV keeps resetting itself with the two screen option, either side by side or small box inside larger screen appearance. There is no menu under screen to manipulate. There is only volume,channels,and tv/cable buttons. I don't don't have the original remote. Is there a different remote that I should buy or do I need to push buttons in a certain way? I have replugged it many times but it still won't reset.
Problem is now resolved! We found that Radio Shack has a preprogrammed remote for just twenty one dollars. The man that sold it to us showed us which features on the remote fix the problem. He was right (love Radio Shack because they are so helpful!). It is a Universal HDTV PRO Remote Cat. no. 15-135 (on the back). We had bought a different universal remote, but the man said that we needed this one, and he was right.
Posted on Feb 21, 2009
Factory reset sony tv
Sony Google tv can't make factory reset went I try I just have a black screen help please
Jan 09, 2014 | Sony FD Trinitron WEGA KV-32FS16 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color setting for Sony XBR Trinitron 36" any settings
Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My sony trinitron tv keeps blinking on and off.
Leave tv unpluged overnight to reset the main board.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Nov 11, 2008 | Sony KV-32S42 32" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Mar 26, 2006 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
