Question about Apple iPod nano
Ipod not working properly scroll wheel not working
I asked 4 help where do i find it seems lkie all u want to do is sell a service correct
Posted on Feb 21, 2009
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
How do I properly turn off my Ipod?
Hold down the "play/pause" section of the scroll wheel for a second or two.
Feb 20, 2011 | Apple iPod classic MP3 Player
Ipod will not scroll and already restore and upgraded
i assume that what you mean is that the scroll wheel is not working; you cant select different menu items with it.
this is problem a hardware, rather than software issue (e.g. physical damage)
you have some choices at this point:
1) try and fix it yourself. this can be difficult
go to ifixit.com
they have both the parts for the repair, as well as the instructions on how to do the repair itself.
2) send it off to apple to fix
this will be very expensive and slow, i don't recommend this.
3) sell it, and buy a new iPod.
Oct 31, 2009 | Apple iPod nano
Ipod nano 8GB doesn`t work
Hold down the middle button and the top of the scroll wheel until you see the apple symbol. Keep holding the middle button then hold down the bottom of the scroll wheel. This will reset the iPod so that it will work. If the scroll wheel is still not working, take it to the place you purchased it or if it is in the area, find a local Apple Store and take it to them. They will be able to assist as well.
Oct 27, 2009 | Apple iPod nano
Ipod 4th gen. the wheel does not work + I can't scroll through menu
You'll need to replace the click wheel. You can get one on ebay for about $10 and put it in yourself or let a repair shop do it for you for about $40.
This is a common problem on ipods.
Jan 29, 2008 | Apple iPod MP3 Player
Scroll wheel is nonfunctional
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 11, 2007 | Apple iPod MA446LL/A MP3 Player
How can I identify which iPod model do I have?
"This document will help you determine the model of iPod you have as well as the latest version of iPod software available for your model. To ensure that your Mac or PC is compatible, check the system requirements for your particular iPod. You can always download the latest iPod software at http://www.apple.com/ipod/download/. You can tell which iPod model you have by checking: If it has a scroll wheel, a touch wheel, or a Click Wheel. The size of its hard drive. The dock connector. Icon Model Year-Month introduced Scrolling device Drive size Current iPod Software Version iPod nano (4 GB) 2005-09 Click Wheel 4 GB 1.0 iPod nano (2 GB) 2005-09 Click Wheel 2 GB 1.0 "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano Logo
50 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
