Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
I ordered all necessary parts to replace the heater element but it came without any instructions - how can I get the instructions and does the dishwasher need to be pulled from the opening to replace the heater element?
  • Anonymous Mar 15, 2014
    water not heating, ordered the part but don't know how to replace it
  • 117 Answers
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Mar 18, 2015 | Element Water Heaters
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
Start shut down
follow this steps and use the Voltmeter, and fix it. God bless you
oubleshoot a thermostat:
  1. Shut off power to the heater at the electric panel and post a sign warning others not to turn it on.
  2. Unscrew and remove the electric water heater access panel.
  3. Using a small screwdriver, turn the thermostat dial counterclockwise to lower the temperature, or clockwise to raise it. If the water heater doesn't maintain the proper temperature, test the thermostat.
  4. Disconnect one wire to the upper thermostat to test it. Set a multimeter to RX1 (resistance times 1) and touch a probe to the thermostat terminals as indicated in the owner's manual. Depending on the model and the terminals tested, the tester should show infinity ( open) or about 0 ( closed).
  5. Test the lower thermostat in the same manner.
  6. If necessary, replace the thermostat. Unscrew it from its mounting and install one of the same model, size, and rating. Once you install it, adjust the thermostat following instructions in your owner's manual.
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  1. Disconnect power to the heater at the electric panel and post a sign warning others not to turn it on.
Some elements is in Short circuit, test the procedure before
Oct 09, 2013 | Water Heaters
4 blinks / high temperature shutdown
some elemente is in short circuit. test the follow steps and fix it. God bless you
Oct 09, 2013 | Reliance Water Heaters
No hot water volume at shower until power is turned off and on to unit
follow this steps and fix it. God bless you
Oct 08, 2013 | Noritz 6.3 Gallon Residential Tankless...
If everything else works why wont the heat come on. the water is still hot and the ac and the fan works but no heat
Troubleshoot a thermostat:
Oct 08, 2013 | White Rodgers Water Heaters
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
My water heater has power at top element but not bottom...however the top element will not turn on either
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 28, 2011 | Rheem Water Heaters
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Typical energy smart manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Jan 11, 2011 | Whirlpool Water Heaters
The dishwasher is leaking water from were the heating element goes through the bottom of the dishwasher
The heater element got 2 screw legs that if it is a metal lock then they get rusty you need to replace the lockers for the heater legs and its not coast much what is your model # ? I get you the parts number so you can order them and do it yourself...
Jan 24, 2010 | Whirlpool Dishwashers
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
387 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
