Shutdown
Causes:
Cause #1
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Comments:
Feb 20, 2009
Shutdown
Causes:
Cause #1
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65315 65 in.
Mitsubishi WS-65315 65 in. Rear Projection HDTV-Ready...
I have a Mitsubishi WS-65315 that changes inputs intermitantly. I'll be watching something on input...
(More)
I have a Mitsubishi WS-65315 that changes inputs intermitantly. I'll be watching something on input 2 then it changes DTV. Never seen it do this but heard it drop the volume and when I went to check it was on input DTV. It may have turned off and on. Not sure. No codes flashes 12.
i have found out how to connect my dvd player and playstation 2 to imput ports 2&3, but when...
(More)
i have found out how to connect my dvd player and playstation 2 to imput ports 2&3, but when i try hooking something into imput port 1, i try pressing imput and cycling through but no indication that a connection is clear.
I will plug the mitsubishi into an outlet and the green power button will turn on for a second......
(More)
I will plug the mitsubishi into an outlet and the green power button will turn on for a second... then turn off and blink three times. I just got the TV and dont know what it is... could you tell me
Was watching, picture just went on. Screen seems to be somewhat lit and what is lit shrinks and gets...
(More)
Was watching, picture just went on. Screen seems to be somewhat lit and what is lit shrinks and gets bigger.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
