Question about Office Depot Ativa DQ60M Shredder
When I insert pages it start making a loud noise like if the blades are rubbing aginst the plastic. Has anyone have a solution?
  • 35 Answers
Chances are with this model, you have overloaded the infeed and broke the plastic drive gears.
Good luck on finding service and parts because on these cheeper products, the parts are almost as expensive as replacing the machine.
Posted on Mar 03, 2009
Hunter fan #22441 makes clicking /rubbing noise,all speeds,blades are tight & and balance is good. what next???
the plastic cover retainer screw above the blades
.if the noise is there when spinning at all speeds
check its clearance with the blade motor center
may have dislodged it is quite possible to rub and click
even if it has a reverse direction switch there....
this is the hunter typhoon 48 in
Jun 18, 2016 | Hunter Dryers
Garbage disposal makes loud noise, nothing stuck, blades turn freely
Bearings in the motor are worn enough to allow the grinder plate to rub against the side of the chamber.
Apr 10, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Loud squeaking/ squealing noise when turning wheel
Have you had your wheel bearings checked. With the front wheels straight, back up about 50 feet then pull forward about 50 feet. You will need to do this on level ground. Then from about 25 feet in front of and behind see if any of your wheels look like they are tilting in at the top. If so jack that wheel off the ground and see if it moves in and out at the top. If so its likley the wheel rubbing aginst the backing plate of your disk brakes. Let me know what you find
Jan 09, 2014 | 1991 Mitsubishi 3000GT
My 1998 chevy caviler has a grinding noise when i step on the gas peddle & rev it up, what can this be?
this could be anything i assume your hearing it under the hood. with the engen OFF pop open the hood and see if the fan blades are rubbibg aginst the fann schroud. check the end of each fan blade for possable signs of rubbibg check around the schroud for rubbing or anysign of rubbing. i dont know what type of noise your hearing you might want to check the belts make sure they are in place. and the pullys to make sure there is no movement other than turning the way they are supposed to go. if you cant see anything have a friend over and being very carefull with the hood still up have them or you start the car while the other one watches and listens under the hood. [KEEP HANDS BACK] have them rev... a little on it to see whats making the noise. and im sure youll find it. remember it has to be a moveing part making the noise..i hope this helps
Jun 04, 2011 | 1998 Chevrolet Cavalier
Super super loud vibrating noise loud as race car 110 db i took apart and saw that the screws in the plastic housing surrounding the blower motor had fell out (all of them x4). because of that the...
yes the turbine blades are spinning very fast if the out of ballance this is whats making all the noise it will also shake its self to bits very soon change the turbine fan
Nov 28, 2010 | EuroTech EDC158 Electric Dryer
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
I am not having much luck with blade alignment on my delta model 36-650 table saw. I have all the factory components that the saw came with. The 10 inch blade rubs on the table insert on the far right...
Check that the washers on the motor shaft are positioned properly. I believe the washers are dish shaped one should be on each side of the blade with the wide shoulder aginst the blade. Check this. Also if you go to Deltaportercable.com you can get an owners manuel for free on line. If this was helpful, please leave feedback.
Thanks, Snugglepants
Nov 02, 2009 | Delta Saws
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Jun 02, 2008 | Heating & Cooling
Office Depot Ativa  DQ60M Shredder Logo
168 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
