Question about Goodman GMS90703BXA Heater
Goodman heater blower runs on own won't stop after flame shuts of
Blower will start and stop on own even when tempeture is above the one set on the thermastat.
  • 1,420 Answers
Bad blower relay or timer. replace board.
shorted thermostat wires. check.
Posted on Feb 20, 2009
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
After one heat cycle, the blower motor keeps running, even after cool down is complete. The furnace will not refire until i turn off the power and wait about 20 minutes for a reset.
your limit switch is opening up, that causes constant fan. Check for flashing codes after flame shuts off and fan continues. Check airflow, filters, lack on return air for possible hi temp limit problems.
Nov 17, 2011 | Goodman Heating & Cooling
Goodman model PGB036075-1B will start the gas and the burner but will shut down before blowing heat. Is it a bad switch?
Hello, sounds like either a dirty flame sensor or open limit switch. First try cleaning the flame sensor by turning power off to the furnace and using some steel wool. If the flame sensor checks out good then you limit switch is opening becuase of lack of airflow. check air filter, clean blower wheel, and check to make sure the blower wheel is running at proper speed and not dragging sometimes cause by a weak capacitor.
Mar 06, 2011 | Goodman Heating & Cooling
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
Fan and heater run fine but fan does not shut off for a long time
Check the diagnostic indicator.
1. If the blower runs for hours make sure the fan switch on the thermostat is set on "auto".
2. The furnace safety system must be in lockout. This is the furaces way of telling you there is a problem.
3 Most common problem is a dirty flame sensor.
Feb 20, 2009 | Goodman GMS90703BXA Heater
BLOWER CONTINUES TO BLOW COLD AIR AFTER REACHING DESIRED TEMP.
There is a little switch on the circuit board. Look closely at the wiring diagram and it will indicate which switch to adjust. If not, review the operating manual for details.
Nov 24, 2008 | Goodman GMS90703BXA Heater
Goodman GMP125-5 Air Handler
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Jan 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman GMS90703BXA Heater Logo
175 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
