Question about Dewalt DW887 Heavy - Duty 1 - 1/2" Die Grinder
I need to find a repair manual for a dw887 die grinder
  • 2,176 Answers
You can get a parts schematic and instruction manual at Dewaltservicenet.com just by typing in your model and then you click on the one with your type number. As far as a repair manual they don't have one Let me know if you need any more help
Posted on Feb 21, 2009
How to fix a die grinder
a more Discriptive question is needed.
Apr 09, 2013 | Makita 14" Die Grinder
Where to plug in brushes on my dw887 die grinder
Remove the back halves of the housing (where the cord and switch are). Once you have the halves opened, you'll see the wires on the brushes going in by the motor. There are coil springs that hold them down. Take a paper clip and lift those springs up and rest it on something. (You can completely take the springs out but you don't need to.) Then slide the old brushes out. Detach the wire and replace with the new ones.
Make sure when you are reassembling the housing halves to keep the wires from being pinched.
Apr 24, 2012 | Dewalt DW887 Die Grinder 1-1/2
How do you reset a makita gd0600 die grinder?
How much wear has it had. The carbon brushes could have worn out and need replacing.
Jan 28, 2012 | Makita Gd0600 Die Grinder
The Dewalt DW888 Die Grinder does not come with a guard. Is is permissable to operate it without one?
on a die grinder like this one yes you can, make sure that you do wear safety glasses though
Jan 18, 2011 | Dewalt DW888 Die Grinder
The worm gear broke
Time to buy a new air grinder!!
Aug 27, 2009 | Viking Die Grinders: 1/4" Mini Die...
Cannot figure how to get the point onto the die grinder.
Here is a link with illustrations on installing grinder points. Scroll about 1/4 of the way down and you'll see two links for "Operators Manual" Click the one that matches your model.
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=5192
Hope this helps you out.
May 31, 2009 | Milwaukee Tool Milwaukee 5192 4.5 Amp Die...
Safety Machanism Question
Most die grinder throttles feature a spring-loaded "kickstand" mechanism between the throttle lever and the body of the grinder, which prevents the throttle from opening (being pressed down towards the body of the grinder) without operator intervention. This prevents the die grinder from accidentally activating.
Aug 27, 2008 | Taylor Pneumatic: 1/4" Extended Die...
Regular grinder and die grinder difference
Die grinders are specialty handheld power tools designed to shape and polish the insides of cylindrical objects. They have long thin spindles and shafts that allow them to reach deep inside the work piece. Die grinders are usually used in machine and metal working operations to port and polish the insides of piping and plumbing systems and joints
Aug 27, 2008 | Taylor Pneumatic: Three In One Kit
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Aug 27, 2008 | Viking Die Grinders: 1/4" Heavy Duty Die...
Die Grinder usage
these tools are handy for any finishing or grinder that needs to be done in a small spot.
Aug 27, 2008 | Taylor Pneumatic: 31 Pcs. Sanding Prep....
Dewalt DW887 Heavy - Duty 1 - 1/2" Die Grinder Logo
307 people viewed this question
Top Dewalt Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Dewalt Grinder Expert? Answer questions, earn points and help others
