Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave stopped working all of a sudden. NO power supply. I tried placing at different places.But no use..I ddidn't see any problem before it stopped working..
  • 1 more comment
  • Anonymous Mar 31, 2009
    microwave stopped working all of a sudden
  • Anonymous Apr 15, 2009
    It really just stopped working altogether. . .weird. In the middle of warming up some rice. . .no power, no display.
  • Anonymous May 03, 2009
    Yes, mine stopped working, cooking some instant rice.  I have had no luck getting it to power up again.
  • 52 Answers
The most common problem with microwaves is the door protection circuit blows a fuse. the door catches operate switch that if they do not operate correctly( normally after the door has been slammed). the good part is they place the fuse inside the casing. so remove the power open the casing( several screws) and check all the fuses in side.
Posted on Feb 21, 2009
This seems like a pretty easy fix. I've had a GE microwave where the handle basically breaks off so you can't open it which is a real pain. Lots of complaints about that one! Apparently you have to be careful of what you use to clean microwaves as windex seems to be a bad choice. Whatever type of door protection they use on microwaves disintegrates eventually after too much ammonia. http://buildsitepro.com/home.asp
Posted on May 14, 2011
MY microwave just stop working all of a sudden what can I do
-Have you try to plug it to different outlet to see possibly the outlet has no power. Or try different circuit to plug into the one the microwave plug in to see it work or not. If no work then there is not power at that outlet. The breaker is pop.
But if it works then you possibly need new microwave.
Good luck
Mai
Dec 13, 2017 | Microwave Ovens
I have a Electrolux integrated microwave suddenly stopped working found the internal fuse had gone . Would just replacing this work or is there a bigger fault due to fuse going in the first place .
Fuses blow for a number of different reasons. Here's a partial list:
Bad door switch
Door switch sequencing issue
Weak fuse holder
Problem in high voltage circuit
Mar 02, 2017 | Electrolux Microwave Ovens
During cooking,microwave stopped,no power.
Not good news; Panasonic uses a technologically superior power supply with higher efficiency but an overall worse record than those using a 'linear' supply with far fewer parts and a good track record of reliability.
The modern (switched mode) power supply places a lot more stress on components and requires more and higher quality parts than the old-style circuit.
Feb 21, 2015 | Panasonic NN-SD681S - Genius Prestige...
My microwave stopped working suddenly, the fuse is ok, power supply ok. It is built in can you advise please.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
May 16, 2011 | Electrolux EMS2487X Convection Microwave...
My microwave is now running at half power, even though the power level shows 10 on the display. I have to double the time to cook everything. I tried cutting the power to the m/w, and then turning it back...
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Mar 20, 2011 | Panasonic NN-S252WF Microwave Oven
My Bosch innowave microwave oven is 3 years old. It has suddenly stopped cooking and heating food, yet the light comes on and the turntable works. Please help.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
Jan 23, 2011 | Bosch Microwave Ovens
Oven suddenly stop working, think the fuse may be blown but have searched for a place to purchase the fuse with success. Where can I purchase a fuse?
if you have a radio shack around they normally carry these fuses....i am in texas and out guys working on appliances go to home depot to purchase ....
a company called
www.repairclinic may be able to help
or www.apdepot.com you can try
hope this is some help to you.....
Jan 05, 2011 | Sanyo EM-S9515W Microwave Oven
The emerson microwave suddenly stops working,no power supply.
Check the fuse on the floor of the oven. find it near where the cord enters the box.
Oct 15, 2009 | Maytag MMV1153A Microwave Oven
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Lost power suddenly
Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
http://www.partselect.com/microwave+replace-fuse+repair.htm
Jan 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
3,236 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
