Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
I am trying to connect my D-Link router to my PC. I changed providers from DSL to CAble, and now it doesn't work. When I try to hook up the router to the cable modem, I no longer have internet service....
    Novelist:
  • 126 Answers
First, you have to directly attach to the cable modem whichever computer the instal tech used to establish your account. Make sure that connection works. Then re-insert the router and clone the MAC address of the instal computer to the router. Then check your DHCP settings. Make sure it's set to get a new IP from your new provider. You may then have to then release your IP and resubscribe.
Posted on Feb 20, 2009
Ni wifi connection on the router itself, what could be the possible cause of it.
IT MAKES A DIFFERENCE IF YOU ARE HOOKING UP FROM DSL OR CABLE
IF DSL MAKE SURE ARE YOUR PHONES HAVE FILTERS
IF CABLE MAKE SURE THAT IS CONNECTED RIGHT
UNPLUG EVERYTHING
INSERT CABLE OR DSL INTO INTERNET SLOT ON ROUTER
THEN PLUG THE ROUTER IN LET ALL THE LIGHTS COME ON
THEN TURN YOUR COMPUTER ON AND SEE IF IT REQ THE CONNECTION IF THE LIGHTS ARE ON THE ROUTER MOST LIKELY COMPTER IS NOT CONNECTING TRY CONNECTING WITH ETHERNET CABLE
Feb 15, 2011 | D-Link DIR-300 Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
I have DSL modem and before that I was connected through the internet by cable and it worked on my both my computers (Alienware and MAC) with the router DGL-4500. Now I changed internet providers and have...
Check the IP address of the computer.
If you aer getting the Ip address on the computer then try to ping the router.
You have changed the ISP. there is difference between the cable and DSL service provider. settings are different.
You will need to set up the router from the start.
Click Here for more info about how to set up the router
Oct 22, 2009 | D-Link DGL-4500 Wireless Router
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
AT&T FastAccess DSL & D-Link not working for me
Yes D-link is compatible with DSL. What you need to do is call your ISP and have them bridge your DSL modem. Next you need to verify your username and password for your internet account. Next call d-link and have them help you change your router's setting to work with PPPoE connections.
Sep 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
Can't seem to hook up D-link router to my Arris cable properly
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
I'm having trouble hooking up my zonet wireless router. I put the cd in and did everything but it still wont work.
Are you running a DSL connection, or is it cable? If you have a DSL connection, the router IP and the DSL modem will conflict with each other trying to establish connection. This may be something to call zonenet customer support on to find out if it is possible to change the router IP address so they don't conflict. If you want to basically "PLUG and PLAY" return the zonenet router and get a D-Link wireless router. They are most compatable with DSL connections.
Mar 14, 2008 | Computers & Internet
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
NEED HELP ASAP!
The PC and Mac don't interact when they are connected to the router. The router provides a DHCP server, and the PC and Mac should simply log in to the router and run fine. If the router is a new addition too, you'll need to connect the WAN port on the router to your DSL or Cable Modem's ethernet port... and then hook up the computers to any of the open ethernet ports on the router. An ethernet port looks like an extra large phone cable connector.
Sep 16, 2007 | D-Link (DI-711) Router
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
227 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
