Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Need a replacement screen for a phillips 51 in rear projection screen tv - hopefully a used inexpensive one as this is an older tv!
I found them online right from Philips. Look for the alternate screen that is only about $170.00 US
Posted on Jun 22, 2009
Red convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Philips 51PW9303 51" Rear Projection...
Phillips 51pw936317f picture not as sharp as when new
Jan 17, 2009 | Philips 51PW9363 51" Rear Projection...
I have a 51 inch phillips seeing almost a 3 d effect
Your convergence chips are toast. You will need to replace them along with the convergence resistors.
Here are some of the common symptoms when your convergence chips fail.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed, wavy, etc but stationary.
Solution:
You can get a convergence kit with photo instructions from www.TvRepairKits.com
Dec 17, 2008 | Philips 51PW9303 51" Rear Projection...
Phillips model 51pw9363 Convergence Problem
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Nov 30, 2008 | Philips 51PW9363 51" Rear Projection...
Colour misalignment and focus
You need a new convergence board. Not an easy fix, sorry.
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Scratch Screen
Sorry about the late posting. The protective screen can be purchased from Tritronicsinc.com using the part number KR2074. This will cost $80.36 plus shipping. This should be a straightforward replacement. The instructions are included with the screen.
Hope this helps,
Dan
Oct 13, 2008 | Hitachi 51F500 51" Rear Projection...
Phillips 51" Screen Distortion
See if the issue happens in the menu alsoif not replace the small signalbaord.
Apr 25, 2008 | Philips 51PW9303 51" Rear Projection...
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
