Question about Magicard Rio Card Printer
Magiccard Rio printer is giving error code 24:24
Unfortunitly no additional details. printer just stopped printing and displayed error code. did clean the heads/rollers, as well as turning off then back on...thx
    New Friend:
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Posted on Jul 17, 2013
3 Suggested Answers
SOURCE:
magicard
  • 71 Answers
SOURCE: Flipper Error
Hi There,
Can you let me know the error number?
It should look like '200:??' or similar. This number tells you exactly what was happening before the error occured.
Where exactly has the card stopped when you get the error?
Is the blank side facing up or down?
Here's a few things to check;
NOTE: Later models of the Tango 2 printer has a white Mylar shim fitted to the end of the platen (where it exits the print engine to the flipper unit. This is very easy to fit. Magicard can supply you with this if you need it. This shim prevented the card hitting the card front sensor when it was fed back to the platen from the flipper to print the card back.
Remove the square panel in front of the lid latch (it slides to the back and lifts out). Check that the Black rubber roller is in the center of the card path. Sometimes it can move to the left.
Turn the flipper round by hand. There is a white nylon roller on the underside. This is held against the Black rubber roller by a flat sprung metal plate. Sometimes the ends of the spring can distort if the flipper had two cards at the same time (check the thickness adjuster behind the Black cleaning cassette.
Lastly, is the front fascia in line with the printer's side panels? If the fascia is loose and is sitting higher, this can cause the flipper to jam (the card hits the card exit molding while flipping.
Make sure you have the latest firmware installed. The firmware version is displayed during boot up. It is also printed on the internal test card if you press the test button on the back.
Latest version is currently V2.05. You can download this here.
Let me know if any of the above helps.
Regards,
MC.
Posted on Mar 20, 2008
  • 7 Answers
SOURCE: Card Jam 02:16 Error in Magicard Rio 2E Printer
Check the front rollers all turn when the cleaning button is pressed with the top open.
Check the front pinch rollers on the thin metal shafts are pulled down onto the cards by their springs. Check that the ends of the pinch roller shafts are retained in the plastic cam followers. The card is not being gripped to drive it back to print the Magenta panel.
Posted on Feb 17, 2010
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete ยท Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
Error code 24:06 magicard
Hi There,
General Error 24:06 may indicate a problem with the front card sensor (very rare though). Open the lid, remove the dye film. Check that there are no cards jammed near the front of the printer (just before the flipper unit).
Try unplugging the printer. Cancel all print jobs if any are pending.
Plug in the printer. Once initialised, open the lid, run through the cleaning sequence (a Magicard cleaning kit - 3633-0053 is required). If the problem persists even after cleaning, contact your Magicard dealer. The warranty status can be checked here;
http://www.magicardonline.net
Enter the serial number of your printer in the QuickSearch box (Menu -> Info -> Serial Number)
Hope this helps,
MC.
Apr 14, 2014 | Magicard Rio Card Printer
Code error 24:10
ISSUE: The printer front panel displays System Error 24:10. The printer may not print, and in rare cases, ink may leak from the printer. SOLUTION: HP is investigating a recent issue with some HP 91 Ink Cartridges in HP Designjet Z6100 series printers. A combination of factors related to handling during shipping have resulted in a very small incidence of HP 91 Ink Cartridges with the System Error 24:10 error. When the problem occurs, the printer front panel displays System Error 24:10 and the printer may not print.
HP regrets any inconvenience this may cause. Please contact HP Customer Support for assistance. Click here for information on how to contact HP support at http://welcome.hp.com/country/us/en/wwcontact_us.html.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Error code 24:03 magicard- card was stuck in machine
Hi There,
General Error 24:03;
This error is caused by a faulty RFID tag in the colour dye film.
Contact your Magicard dealer for a replacement dye film.
Sep 06, 2011 | Magicard Rio Card Printer
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code [email protected]
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have an hp laser jet color printer 4650n which is giving me a code of 49.4C02 service error
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font.fix printer error 49.4c02
Hope this helps you.
Sep 01, 2010 | Office Equipment & Supplies
Printing stops and gives error code
The error is caused by either the cartridges or the encoder strip. Here's a link to the Lexmark website to guide you on what to do. Just click on this link: http://bit.ly/affECc .
Mar 31, 2010 | Lexmark X5150 All-In-One InkJet Printer
File Error (c600)
Hi There,
I'm sure this must be a coincidence.
When the ribbon snapped, did the printer report and 'Out of dye film' error on the PC (via the Status Monitor)?
Did you install the latest version of the driver (V6.02 is compatible with both Rio 1 and Rio 2)?
You can download this here;
Just enter your printer's serial number in the QuickSearch box.
If you are updating to a later driver version, please make sure you choose 'Update driver files' rather than 'Add a printer when give the choice (you will need to restart your PC).
I hope this helps.
Regards,
MC.
Jan 27, 2009 | Magicard Rio Card Printer
The cards are sticking
Hi There,
Im_useless:
0.126 is not a Magicard error number. On a Rio 2 printer, the error number will be displayed on the LCD display. It should look like 02:?? or 04:??, etc.
Are the cards feeding out of the hopper?
How far into the printer have they gone before you get the error?
Are any of the dye film panels printed before the card gets stuck?
Are the cards ejected when you click on 'OK'?
Guest:
The most common reason for the dye film sticking to the cards are if they already have overcoat printed on them (you can not print over overcoat). Also, if you are printing very dense images, try selecting 'ColorSure' mode in the printing preferences, Try reducing the YMC printhead power in printing preferences.
Nov 30, 2007 | Magicard Rio ID 2 Card Printer
Magicard Rio Card Printer Logo
1,357 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Clive
Clive
Safe-Card ID...
Harrie
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
