Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Water dripping in refrigerator
Whirlpool refrigerator - 1997 modelI have a Whirlpool refrigerator model ET22DKXFW00
I purchased it in March 1998.
The food is not jammed against the air duct.
The condenser coils have no dust on them
The door gasket is brand new
Water is dripping onto top shelf of refrigerator from the control panel cold air supply duct.
What's wrong with my refrigerator?
  • 1 more comment
  • BailMeOut Feb 21, 2009
    How do you go about cleaning the drain tube? I took the lower back panel off and after vaccuuming all the dust I can see about 10" of the drain pipe, but I can't see where it goes. Up in the freezer there is a piece of stainless steel sheet metal under the evap coil; this stainless looks like a drip pan somewhat. Does the drain tube begin in this pan because I don't see it!
    I just removed the right side styrofoam 90degree duct and hiding behind it was the "frozen solid" drain hole! After 2 hours of hair dryer I finally fished a long piece of wire up from the condensate pan and broke the ice jam-then the water came out. So now I know for next time. Thanks to all for providing food for thought in my refrigerator problem.
    (It still amazes me that you open the door and the light goes on...lol.)
    aborcass; you are correct, sir. (Fan fare plays in the background)Thanks for the explanation-my first thought was a freon leak and an iced up coil.
    But I take this.
  • 547 Answers
There is a drain in back of fridge it need to be cleaned outif you look top center you should see it little plastic pice runs out back of fridge and to a tray under witch then evaporates between freezer and hose you have a clog clean this out and leeking will stop thank you for useing fixya please rate me
Posted on Feb 21, 2009
  • 1 more comment
  • albert getty
    albert getty Feb 21, 2009
    no look in side fridge
  • albert getty
    when you pull this out make sure hole between freezer and fridge is clear thank you again for useing fixya
  • albert getty
    you will most likley find a pea or peice of corn lol
    Scholar:
  • 140 Answers
The TD (temperature defferentail) in too wide in your fride, (i.e th freezer is much, much colder than the fridge.)
You need to return the adjustment controls to the center position for each setting. (i.e. 1-5 you need to set on 2.5).
Allow the fridge 24hrs to adjust the temps.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
    Novelist:
  • 117 Answers
  • Clean the Drain Tube
  • If you have an ice-maker, check refrigerator and ice-maker for level
Posted on Feb 19, 2009
    Brigadier General:
  • 8,619 Answers
Hi! Is there any frost on the back of the fridge? Try switching it off for half an hour.
  • Rylee Smith
    Rylee Smith Feb 19, 2009
    This happens when the the defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator.
    The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section.
    Cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out.
Whirlpool model#ET22DKXFW00 is how big in width?
Try contacting Whirlpool directly for information.
Jul 25, 2014 | Whirlpool Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
Odor
Could you possibly have a dead rat under there? I know this sounds gross, but they love to hide in the electronics. (Sorry). Anyway, your drip pan may sit on a small bracket type piece that isn't heavy at all. It can sometimes get misplaced, causing the fridge to leak because it's out of place. If you can get a flash light, you should be able to see where it's placed and you should be able to remove and clean it out. I put Mr. Clean in mine when it gets an odor and when water hits it, the solution cleans the odor, but you can clean it and replace it. I hope this helps!
Aug 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
151 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
