Question about Hotpoint Dishwashers
Lost my manual for ultra hotpoint dishwasher 2003
My tenants moved out so i do not know how to work my hotpoint dishwasher. It is a ultra super silent FD W 80. So i would like to get a manual please thanks
  • 686 Answers
You can go to( kitchen.manuals.com ) search there and you'll find it it costs though i don't know how much
Posted on Feb 20, 2009
My Hotpoint ultima super silent dishwasher blocked in the night and tripped the fuseboard. I have cleared the blockage but whenever I turn the mains back on it keeps tripping the fuse before it can resume...
also check for a burned heating element, once you locate the element in the lower dish washer look i over for damage , you could also remove the wires from the lower element and then try ad see if it works ifthe unit works
replace the element
you have a short somewhere just trying to eleminate some items
Oct 31, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Water is standing in the bottom of the dishwasher
I must assume it is an older Hotpoint made by GE. Remove the lower panels.(4 phillips screws). Black or silver motor is facing you. Left of that is the drain solonoid. It has a silver bar/plunger on the top and should be in the UP position normally. push down on the bar- it should move freely. If not, you need a new pump motor assembly. If this is the case, I would recommend going for a new dishwasher. This is also a good time to check for leaks, The old GE's are know to be silent leakers until it is too late. Hope this helps!
Ken
Oct 01, 2010 | Hotpoint Dishwashers
My tenant had a problem with plastic stuff all over her dishes, she said the packaging inside the door was melting and getting all over her dishes, have you had this problem before? What do I do? now the...
all that packaging material is for shipping purpose only styrofoam ,tape check out the instruction manual under unpacking that plastic is most likley used to stop scraching during shiping
Apr 13, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Door does not lock shut but machine still works. Is it easy to repair?
Exactly the same happened to our Hotpoint FWD70. The spring that holds the door latch in place has snapped. I removed all screws out of the door to find the spring and the metal rod it hooks onto and bend another hook into it (I didn't have a replacement spring), put it back together and the door works fine, although for some reason the dishwasher tablet doesn't release now!!
May 19, 2009 | Hotpoint Ultima WF865 Front Load Washer
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine falt
hiya
i think this is either the heater or the heater relay on the pcb, i would suggest givin hotpoint a ring though as the machine may come with a 5 years parts warranty so all you will pay is the call out.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
320 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
