Question about Homelite Garden
Chainsaw is using way to much bar oil
It goes through one tank of bar oil to about three quarters of a tank of gas just wanted to know if there was a control screw for the flow and where it is located?
    Problem Solver:
  • 38 Answers
There should be an adjusting screw usually at the front of the saw, on most saws. usually located on the lower front. the screw puts tension, or less tension controlling the flow of oil. also if that did not help then you might have a broken oil line or it might be diconnected all together.
Posted on Feb 20, 2009
What oil is used fro the chain bar and where to put it please?
90w, look for black plug usually near handle
Sep 15, 2015 | Garden
Chain oiler not working
wow this seems to be a more frequent complaint with folks bringing me there saws to look at lately , what I almost always find wrong is debris in the oil tank hence it's in the oil pump too , this requires a total take apart and clean it out service , also folks seem to not know what oil goes in there and add just any kind they have (even 2cyc oil) me I like to say u use Bar chain oil , this most times is 30w or less if it gets any heavier or lighter the oil pump M/T's the oil tank out first before the fuel tank goes M/T , oiler is not adjusted correct if your not needing to add oil with every gas tank fill
Aug 31, 2015 | Ryobi Garden
I have a UT10947D Homelite chainsaw that uses excessive bar oil. When I use it oil slings everywhere and drips steadily out the clutch cover. I tried clearing the lines and checked for cracked or loose...
check that you are using chain bar oil and not engine oil as that is the main reason for excessive oil usage
make sure that there is the small restriction at the exit point
if that is missing , then that will be your problem
Oct 18, 2017 | Homelite ZR10926 16 Chain Saw
I have borrowed a chainsaw PWR1750CSA from a friend i need to know what oil goes in the tank, i presume it is to lubricate the chain.
The fuel tank takes a 25-1 fuel oil mix, the oil tank takes a non fling chain oil to lubricate the chain, if you you a light oil it will spray off the end of the bar and not lubricate the under side of the bar where most cutting is done, if you cannot get non fling oil use as thick an oil as you can get hold of.
Sep 08, 2011 | Garden
Unit runs great. I beleive I am getting too much bar oil from the chainsaw. There is bar oil dripping from under the cover where the bar connects to the unit. Is there an adjustment for this? I have...
There is no control on how much oil is sent to the chain.
You should be using about a tank of oil to a tank of Gas
Things to check Are you using Chain and bar oil or regular oil
Chain and bar oil is thicker and has additives to make the oil stickier. regular oil is thinner and tends to run out of the saw when you are not using it.
If you are using correct oil and using to much sounds like the oil pump needs to be replaced
Jun 27, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the gas- oil mix to use for fuel?
Check the cap on the fuel tank normally for chainsaw 40:1 or 50:1 this additional oil is the only lubricant these engines get as they are 2-stroke & do not have a sump of oil for the engine.the other oil is only to lubricate the chain & bar & uses a tacky oil . only mix small amounts of gas for use as it goes stale.
Aug 16, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
158 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
