Question about Hobart H600 Stand Mixer
I need to change gear oil in Hobart H600 mixer.
I found the drain plug but I can't find where to pour in the new oil.
  • 640 Answers
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Posted on Feb 20, 2009
  • Josh Schlueter Feb 01, 2013
    There are two oils, where do you drain and fill each of these?
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
About how many time you must change the oil.
For most applications once every two to three years should be fine.
Feb 02, 2010 | Hobart H600 Stand Mixer
Oil
the part# for the oil is102973-71, that can be bought @any hobart office in your area
Jan 13, 2010 | Hobart H600 Stand Mixer
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
Howdy, We have a Hobart H600 mixer and it looks like it needs oil. Where do I add the oil and what type should be used? Wesley McMenamins Pubs & Breweries
take off top cover, where the front screw on top cover threaded into is the fill plug for the trans.drain oil replace drain plug , also ck. sight glass if dark or cloudy replace,@this time.trans. oil can be bought @ any hobartoffice the part# for the trans. oil is102973-66 that will come in a 128 oz bottle you will not need all of it. pour a little @ a time till oil hits line on sight glass. please vote thanks
Oct 16, 2009 | Hobart H600 Stand Mixer
How do you change the oil in a hobart h 600-dt dough mixer & what type of oil do you use ?
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Oct 15, 2009 | Hobart H600 Stand Mixer
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Hobart H600 Stand Mixer Logo
707 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
