Question about Copystar CS-2030 Copier
I cannot find the manual for this copier
I need to know how to take a 2 sided copy and make a 2 sided copy of it!
Thanks
How come it seems nobody checks the Mfrs. website for the info they want?
Here's a link to your manual:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=5200&pcat=10564&rcid=10009&rscid=10028#bottom
Posted on Feb 20, 2009
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Can this copier do both sides at the same time
According to the copier specs, the CS-2030 requires that an add-on duplicator unit be installed for double-sided copying.
May 14, 2008 | Copystar CS-2030 Copier
I have a Lanier LD335c here at work. I need to store a file on the Document Server. The doc I need to store is a 2-sided paper, and I need it to automatically print as a 2-sided paper when it is selected....
Make all your settings on the copier side as if you were going to copy it. Set the duplex for 2 to 2 as I am assuming your original is 2 sided and any other settings you need. Then select the document server button, set your document name (if you want to change it from the copier default) then press the print button to scan it in. Pretty simple but if I understand your question correctly this should do it. The trick is you need to select the duplex/color/ etc settings before you go to the document server screen.
Good Luck
Feb 25, 2010 | Office Equipment & Supplies
I need a manual for the copier part only for my DP 2000. It is not used as a printer, and I do not need to know about that part of it. The console says that the battery needs to be replaced. I need to know...
the battery allows back up of settings. the battery is on the side of the control panel and you can buy from any shop that stocks-- it's not a special battery. the duplex function is within the machine itself. the console is purely for paper supply.
Sep 28, 2009 | Panasonic Workio DP-2000P Copier
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
On the X4850 2 sided printing I am trying to make copies of a 2 sided documet , in other words front and back , it only scans one side and than I have to flip it , I need 200 copies dont want to flip ,...
Download the user guide and follow the steps on page 81 of the manual:
http://safemanuals.com/user-guide-instructions-owner-manual/LEXMARK/X4850-_E
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 05, 2009 | Office Equipment & Supplies
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Copystar CS-2030 Copier Logo
117 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
