Question about Kenmore Washing Machines
I have a kennmore portable washer. I have to find a connection so I can attach hose to my kichen sink. HELP
  • 188 Answers
Get one from Sears.
Posted on Feb 19, 2009
Attach hose to sink
what is your question? if it is how to attach there is an adapter that screws on to facet and then you connect the hose piece to that.
May 07, 2014 | Danby DDW1899WP 8 Place Setting Portable...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
Garbage disposal mechanism cannot be disassembled for repairs.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Garbage disposal works and it turns but it sounds as if something is loose in there...it's the Insinkerator 5-81.....Is it possible the cutting blades are loose and if so, how do I fix this?
As long as disposal is not shaking around a lot, and causing pipes to leak, then you can use it until it dies.
Here are basic parts:
2) Disposal which connects to sink basket with metal ring.
3) There is a washer between disposal and sink basket.
4) The dishwasher connects to disposal with a hose.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sink attachment for washer
repairclinic.com, appliance411.com, or ebay.
Sep 15, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
How do i connect a kenmore ultra wash II portable dishwasher to kitchen sink, the attachement on the hose attached to the dishwasher it to big around to fit my facuet
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Aug 21, 2009 | Dishwashers
Kenmore Portable Dishwasher
Go to Sears.com if you have a Kennmore. Under "parts," you can input your model number, which is found on the inside of the washer on the side, and then search for the part. It even has a diagram you can pull up. Unfortunately, this part for mine, and probably yours will only be available by purchasing the entire hose outfit, (about $65).
Aug 29, 2008 | Kenmore 17252 Free-standing Dishwasher
Portable Dishwasher
You have to have a good seal. Get a hose washer from your local hardware store and replace both of them on the hose if they are like a garden hose. If you still don't get any water to the unit, post again and I'll step you through it.
Jan 27, 2008 | Dishwashers
HOOK UP
Most portable washer come with a adapter for the sink so you can hook the fill and drain to the sink. There are some models that only hook the fill hose to the sink and the drain is a seperet hose you hang into a sink. If the unit is new the adapter should have been included with it. If it was used you can get the part at any hardware store or appliance parts dealer. Good luck
Jul 11, 2007 | Malber P21 Front Load Washer
Washing Machines Logo
47 people viewed this question
Sal De
fordexpert
Robert Rankin
