Question about LG DLE2512W Electric Dryer
LG DLE2512 Electric Dryer reads CL, cant power off, unplugged and replugged in, code still there?? Any advice?
THIS IS THE CHILD LOCK FEATURE. LOOK ON PAGE 25 OF THE OWNERS MANUAL TO UNLOCK IT
Posted on Apr 26, 2009
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
The is a CL display on our dryer. What does it mean?
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again.
Hope this helps...
Daniel
Sep 02, 2010 | LG DLE2512W Electric Dryer
LG Dryer displays CL on screen. What to do?
Makes no mention in the manual about a CL error
Apr 01, 2010 | LG DLE2516 Electric Dryer
My dle2514W LG electric dryer is displaying a CL code (Child Lock) and the check filter light is flickering. Clothes are also coming out with static cling (never was a problem until now). I have cleaned...
My dryer had this same problem. I cleared it by unplugging the dryer from the wall for 20 seconds and then plugging it back in. After this "reset" of the electronics, it has functioned for 2 days without a problem.
Jan 13, 2010 | LG DLE2514 Electric Dryer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
CL code on screen and can not use sensor dry options
For model 2514; from LG manual:
Child Lock: Press and hold DRY LEVEL for 3 seconds. A single BEEP Tone is heard, and CL is displayed. To unlock, press and hold DRY LEVEL for 3 seconds. The indicator light turns off.
May 23, 2009 | LG DLE2514 Electric Dryer
LG DLE2512W Electric Dryer Logo
483 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
