Back to:
Tags:
NAD S300 Amplifier
Pre-amp + Integrated + Headphones
By M0nica L - usenet poster
I have a NAD S300 integrated amp which does not have a headphone socket.
Unfortunately most headphone amplifiers have seem to cost a few hundred
pounds so I was wondering could I use the tape monitor output from the S300
to feed a cheap 2nd hand pre-amp (probably NAD 118) and use the headphone
socket from the pre-amp. I realise that the headphone socket on the pre-amp
will be pretty low quality but since I won't using headphones regularly it
shouldn't be a problem.
Gary
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
kioner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Gary
If you want a cheap and cheerful solution (couple of quid) you could buy or
make an adapter to allow your headphones to be connected to the speaker
sockets.
If you want to make one, you just need to connect a couple of resistors in
series with the outputs of the amp to a suitable headphone socket; I would
suggest 150 Ohms, 2 Watt resistors. Has the amp got two switchable pairs of
speaker sockets? If so, and one outlet is unused at present, you could
leave the headphone adapter permanently wired in.
This approach would probably be lower quality than the one you mention, but
it is the way headphone sockets are wired internally on many integrated
amplifiers.
Regards
Tony Skitt
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Pre-amp + Integrated + Headphones:
I don't want to Accept this solution
Solution #2
Helpful (85)
Ross
Rating: 0%, 0 votes
Gary,
This would certainly work, however much better results can be obtained using
a dedicated offboard headphone amplifier such as the
Creek OBH-11. Priced ??129
For more information
Kind regards
Alex Simons
STONEAUDIO UK LTD | HIGH-END AUDIO TAMED
T +44(0)1202 743777
F +44(0)8701371054
M +44(0)788 777 5661
E mailto:
W #
Thank You!
Can you Help with these Amplifiers and Preamps problems?
my behringer europower pmh660m power amp wont power up...
Am using ps3 with hdmi to TV, TV has no audio out from...
Tengo un equipo de audio marca Philips compuesto de...
Left and right speakers work - centre and surround do...
i guess i did it now !!i think shes a gonner !!! i heard...
Loading problems.
Repair Service
Find Amplifier and Pre. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
