Question about TurboChef C3 Single Oven
I am subway owner and when I toast sandwich in my Turbo Chef oven it burns the paper (Paper catch on fire) any idea???
    Novelist:
  • 125 Answers
Hello. Just want to check that you have a C3 oven, most Subway has the NGC unit. If you can check the model of the unit, this would help.
Hope that helps for now.
Posted on Feb 22, 2009
    Scholar:
  • 75 Answers
This can happen when the mags are not running at even powers. Try unplugging the first cap leed going to the t1 transformer be sure to discharge the cap first. then power the mag with your clamping amp meter around the brown wire that runs through the i/o board power the mag and record the amp reading then perform the same test to the t2 transformer and see if they are running close to the same amperage. you may need to change the mags. i have seen this happen alot when people are cooking things like bacon and hash browns. the solution to this is subway has a hash brown basket so you don't use the paper and stop cooking bacon on the paper use the micro instead for this
Posted on Nov 13, 2009
    Problem Solver:
  • 14 Answers
I've often seen the same paper being used over and over. It will eventually catch on fire. A new sheet is to be used for each sandwich.
Posted on Aug 09, 2009
  • 23 Answers
The problem is that the settings are wrong,this could be due to leakage from the microwave side causing the eprom to malfunction.you would need to rpogram this up again.the easy way to spot if has leakage is to watch the diplay to see if flickers.this is the first sign of the problem.hope this helps,regards les
Posted on Jul 16, 2009
    Problem Solver:
  • 6 Answers
My toilet clogs like that too
Posted on Jun 20, 2009
I have F1 - blower error. Also, it give cooling down error. It works at 208 but not at 240. And i am not able to change it to 208 all time. Any solution please.
Ur using Turbo chef or merry Chef oven? Ur error was cause by fan blower for ur heater to circulate hot air inside the cavity for toasting.. Maybe it's now turning or stuck up. What's the. Model?
Jun 09, 2016 | Ovens
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
Jul 12, 2015 | TurboChef TORNADO Electric Oven
I have a turbo chef tornado 2 (subway) ...my keypad doesn't always work. I had a repair company look at it and he said he thinks it's the control board. His reasoning is that the keypad works most of the...
lets start here before taking anything apart . contact the company and see if the parts they think are needed are still available. If so then you could price then and if you decide it worth that price proceed .
Jan 28, 2015 | Ovens
Turbo chef oven not toasting
Heater...top or bottom. Call a tech
Jan 06, 2014 | TurboChef TORNADO Electric Oven
My Subway Turbo Chef is saying wr fail. I self tested and it came up okay, can't find this error message in manual
I have had an F8 error in the past. The wire connecting the top element had broken off. The reason why temperature is not getting up is becaise the top element is not working.
Apr 22, 2012 | TurboChef Ovens
I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
Dec 11, 2009 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
Turbochef Oven Repair
goto http://www.hobartcorp.com/default.aspxs site its hobart.Find the nearest office to you,either they will service your equipment or can lead you in the right direction.
Nov 16, 2007 | TurboChef TORNADO Electric Oven
TurboChef C3 Single Oven Logo
611 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
