Question about GE JVM1430 Microwave Oven
Everything works except when used today no heating
My wife used the microwave this am, but when heating lunch noticed that it did not sound as "loud". I tried it tonight and it souns like the microwave unit is not on, only the fan
  • Anonymous Feb 20, 2009
    I have the same problem. Not sure how to fix. Thinking about throw it away.
  • GE Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Microwave Heating Problems
Magnatron or the HV Transformer. Each has a distinct odor, Mag is heavy and thick burning smell transformer is more electrical. Eric
Aug 04, 2009 | Microwave Ovens
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave made loud popping sound and now does not heat.
Hey,
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
GE Spacemaker JVM1850CH03
Chances are it is a bad magnetron, but it may be a bad high voltage rectifier diode.
Some models have a 9-year warranty on the magnetron, so you may want to check with GE Customer Service at http://www.geappliances.com/service_and_support/contact/
The pop and wierd noise makes me suspect the diode has shorted.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Plus there should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 07, 2007 | Microwave Ovens
Not heating
Ok you gave a clue when you said you replaced the magnatron. When you grabed the wires did you get a nice shock from the two wires you pulled off? No Ok the capacitor and the diode is bad cause there should have been a charge on those terminals on the magntron cause thats alot very high voltage is present. so always unplug and discharge those terminals through a resistor before working on unit as it will hurt ya bad. Be carefull also when replacing the capacitor and diode. Good Luck
Jun 04, 2006 | Sharp R-1500 Microwave Oven
GE JVM1430 Microwave Oven Logo
79 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
