When I press the button on the tv the blue light goes out but then the picture does not come on. It's been working fine, no problems. Turned it off last night and then just tried to turn it on this evening and nothing - no picture no sound.
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the
main power supply is probably at
fault and without some technical background and a couple of test instruments,
you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it
stand overnight or at least several hours, remove the back panel and look for a
separate board with mostly larger components on it; it will have a ferrite core
transformer on it and several larger capacitors which are cylindrical and
mounted vertically to the board.
Before touching anything inside,
especially on that board, allow several hours to be safe since the larger
capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating
such as discoloration of the board material, it may not be repairable but if
you can find a part number on the board, you might be able to buy the power
supply and install it yourself.
If there are no signs of heat
damage to the board, there may be companies offering to repair it as a
subassembly instead of repairing the whole set which could be much more
expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most
are capable of switching on and off if a downstream problem is causing an
overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
SOURCE: Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
> I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
SOURCE: Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
SOURCE: I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
