Question about Progressive Computer JSI 6 spkr. Home Theater System with Scan DVD Player, 300W System
No pwer i have a jsi theater receiver and the power wont come on. model #jsi5001 the fuse inside is good. please help, dont want to throw away!!!
  • Anonymous May 21, 2009
    POWER PROBLEMS
I have the same problem
Posted on Aug 07, 2009
Why won't 2004 Ford Freestar start, but the dash lights up?
More than likely a key problem. Dont mess with any fuses. A bad keywhen turned wont make any noise. If you have a 2nd key please try that first. If that is your only key consult a locksmith to see if they can program another key. Dont throw away a bad key it may be able to be reused. Good luck.
Feb 25, 2015 | 2004 Ford Freestar
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
Jsi model js5010
test test 18:30 dfbg
test test test 18:31
Jun 27, 2009 | Progressive Computer JSI 6 spkr. Home...
JSI MODEL # JS5010 sound cuts in and out when using .
Make sure it's not overheating. I have this model and know that it just has a heatsink and no fan for cooling. Make sure nothing is on top of the unit, especially blocking the vent on the right...that's the cooling vent.
Also, check your cable connections to make sure they are all connected properly.
Feb 27, 2009 | Progressive Computer JSI 6 spkr. Home...
Dvd drawer will not open
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using fixya.com
Jan 27, 2009 | Progressive Computer JSI 6 spkr. Home...
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
Pioneer SX-950
Speaker Relay Output Switch was a common problem with most SX models of the 70's. It's the switch you hear click on after about 4 seconds of power switch being turned on. It's still avail. thru Pioneer parts for around $45.
Jul 28, 2008 | Pioneer AVIC-S1 GPS Receiver
JSI js5001 Home Theater
My dvd player won't go on. Worked one day the next day wouldn't work any help?
Jan 05, 2008 | Progressive Computer JSI 6 spkr. Home...
YAMAHA R-V701 MAKES BUZZING SOUND & WONT TURN ON
This could be the indication of an open resistor, or bad Capacitor in power supply. May not be visible to eye, but if you look in PS. there should be atleast one big sized cap and every PS has a bridge rectifier, this is usually 4 diodes in series, check them and see if any open, shorted
Sep 05, 2007 | Yamaha R-V701 Receiver
228 people viewed this question
Top Progressive Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Progressive Audio Player and Recorder Expert? Answer questions, earn points and help others
