Question about Datamax E-Class E-4203 Thermal Label Printer
Only prints ''smeared labels'' with no text even remotely recogniza
The printer is communicating with our program... but will not print text.... the output seems as if it is printing correctly but it only seems to pick up ink as it passes by the ribbon...
  • Anonymous Mar 29, 2014
    Bar Tender will now run in demonstration mode where one character per printed barcode or text object will be randomly changed in the print preview and the actual print output
    Problem Solver:
  • 8 Answers
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Posted on Feb 19, 2009
Cannon MG6120 printer will not print text. I have cleaned print heads several times. I think I have a clogged print head. Which of the 2 black ink cartridges prints text? How do I clean a clogged print...
I think you need to do is reinstall you software driver for the print program and start with known parameters. Then you can try to clean the heads. You should get something out of the printer if the heads are plugged it might be a dot or smear on the paper.
Dec 31, 2012 | Canon Pixma MG6120 InkJet Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Text prints fine. However images are printed smeared. It looks like each image has a mirrored shadow. How can I fix this?
Fist set for default settings, calibrate color.. it will resolve the issue ..even its remin service involment must..
Sep 11, 2011 | HP Color LaserJet 2600n Printer
My datamax will not print labels even though it goes through the process
if the printer seems to function . and when your queued label printes, but no text on label, check to see if your driver will do a test print to the printer. if it does, check your fonts. Some Dmax printers will have a difficulty using TT fonts, especially in serial coms.. Try the printer fonts(datamax0, 1,2,3,4.
Feb 03, 2011 | Datamax DMX E4203 Printer
I am having a problem with the wax ribbon smearing on a thermal label after I imprint on it. Is going to a resin/wax ribbon the only answer?
Not necessarily. It could be a head adjustment. If you are just printing on a blank thermal transfer label stock then wax should be just fine. If you are printing on a colored stock then a resin/wax would be better. We use resin/wax on everything because it is the same cost and runs better. But if you have only blank paper wax will be fine. If you are smearing then I suggest adjusting your head. Even if it printed fine before as your platen roller wears down it will require slight head adjustments to print properly
Jan 12, 2011 | Datamax I-4208 Thermal Label Printer
Text is printing in a different place on each label as if it is offline
Text printed in different place.
Do you mean it's in the printing direction?
If this is the case you have to:
- Check that your label length is correctly programmed
- Check that your sensors are correcltly aligned.
- Check the callibration of the sensors
Sep 05, 2010 | Toshiba B-SA4TP Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Jun 26, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Smearing of printed text.....
yes happed this type of problem.
due to old cartridge. some time ink are dry or drop down in printer. yes its possible some time.
Nov 15, 2008 | HP Photosmart C5180 All-In-One InkJet...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
HP Officejet J5780 All-in-One
your printing program needs a template, based on the label makers specs. That's usually what causes that, not the printer itself.
got backup?
Feb 12, 2008 | HP Officejet J5780 All-In-One InkJet...
Datamax E-Class  E-4203 Thermal Label Printer Logo
174 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
