Question about Kenmore 24032\24036 Top Load Washer
Kenmore washing machine top loading .is there a reset for the flot so u get back the noemal loading for the wather livel
  • 188 Answers
Turn the water level knob all the way past the low level (left). This should reset it.
Posted on Feb 19, 2009
My kenmore serie 300 washer only wash with cold wather no hot wather
If I understand, you are saying that you are not getting any hot water coming into the washer. First, I would make sure that you have hot water available at the washer spigots. SLOWLY unscrew the hot water hose at the hot water spigot and see if you have hot water available. If you do, the problem is usually at the water inlet solenoids, or if you are lucky, the water screen filter. Turn off the how water spigot and unscrew the hose at the washer. There is a screen there at the washer water inlet, see if it is clogged. If not, the problem is most likely the solenoids. To replace the solenoid unit requires some disassembly of the washer.
May 18, 2016 | Kenmore Washing Machines
How to reset my Kenmore elite oasis he washing machine
Aug 03, 2014 | Kenmore Oasis HT 4.7 cu. ft. Top-Load...
I have a Kenmore top load washer, it filled with wather, however, will not do anything after that? Lid is closed and still won't agigtate, or drain
Your lid switch is bad. You should open the control panel, unhook the switch, cut and splice the 2 outside wires together (usually tan and grey colored - NOT THE GREEN ONE). Reinsert the plug, close the control panel and you'll be all set. Don't listen to anyone who tells you that you can't splice the wires - also known as bypassing the lid switch. I refurbish and repair appliances for a living and I warranty for life - I bypass these switches all the time. If you need help opening the control panel and/or doing the bypassing, you can reach me via email on yahoo - smms6776.
Jun 07, 2012 | Kenmore 24032\24036 Top Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
No wather go out
what is washing machine front load? if yes we need to replace the drain pump orelse c;ean the pipe line to to drain pipe,if top load also clean the pipeline of drain remove some foreign object that block the line in drain.
Jan 01, 2011 | Washing Machines
Kenmore ht4 front load washer
this seems to be a control panel issue. if water valve switches, try hot /cold water combos to see if it will start filling
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
159 people viewed this question
Sal De
 Brian Main
Brian Main
