Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher model DU912PFGBO drains very slowly and not anywhere near complete
  • 117 Answers
You may have something obstructing the flow of water through the drain hose. You need a tech to check where the problem is.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
My dishwasher isn't draining after it's cycles.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Whirlpool DU912 Dishwasher
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
Hi
Daniel
Jul 05, 2011 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Whrilpool dishwasher--DU8505SWPQ3, there is always water left on the walls of the dishwasher after a complete cycle is done??? Thanks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Feb 08, 2011 | Whirlpool Dishwashers
Dishwasher slowly fills with water
Greg, at this link you can download available manuals for your unit.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GU1100&siteCd=WHRCOM
Good luck with your repair.
Please take the time to rate this solution.
Jan 29, 2009 | Dishwashers
Whirlpool dishwasher will not drain model # du912pfgbo
Usually it is one of two problems. If you put the knob on spin and there is no noise, it is usually a bad lid switch. This can be easily checked by lifting the lid and listening for a click noise when you put it back down. If you hear a humming noise, I would check your pump for an obstruction. (Tilt the machine back and look for the white plastic with 2 black rubber hoses towards the front, center of the machine. Remove one of the hoses with a bucket and some towels at the ready to catch the water. After getting the water out of it, check inside the white plastic (pump) for any forign objects)
Jun 09, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
362 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
