Question about Haier HLP21E Top Load Washer
How long is the fill and drain hose for Haier HLP21E washer?
I need to know how long the hose is for this washing machine because I would like to keep it outside my bathroom and connect it to the bathroom sink when I use it?
  • 4 Answers
The machine is pretty generous with the drain hose out of the box, about 7 ft. and it can be rerouted to come out of either the left or right side at the bottom. Just make sure to put the end above the level of the top of the machine. Otherwise, it will siphon out the wash water and will never fill. The Chinglish instruction book is in error on this point.
Posted on Apr 17, 2010
No need to worry, you can get a new inlet hose & drain hose of any length at any major hardware store. I have the larger Haier outside my kitchen & got a 10' drain hose & inlet hoses & this same situation was instantly solved...
Howard
Posted on Sep 15, 2009
Water is coming in through the entry hose and running straight out the drain hose. No agitate, no spin, just constant water. Happened after I tried to wash three towels & got an imbalance alarm. R
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Nov 08, 2013 | Haier HLP21E Top Load Washer
Water is running out of the hose
What hose? Intake or drain hose?
If the drain hose makes sure you follow the user manual and set the drain end to the proper height. If it is too low you will not be able to fill the washer. It will just continue draining.
Jul 23, 2013 | Haier HLP21E Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again").
I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
Aug 22, 2012 | Haier HLP21E Top Load Washer
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
Draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Oct 10, 2008 | Haier HLP21E Top Load Washer
No Drainage Stoppage?
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
Feb 06, 2008 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load Washer Logo
527 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
