Question about LG 42LC2D 42 in. LCD HDTV
Sounds vibrate at times - LG 42LC2D 42 in. LCD HDTV
    Problem Solver:
  • 19 Answers
Possibly either bad speakers or bad main board. If it's under warranty the tech will probably replace both.
If it's not, try the speakers first. They're cheaper and usually the culprit.
Posted on Feb 21, 2009
The vibrate mode on my phone will not work
Go to phone app, dial the following number-
*#0*#
You will get a screen with following options (Not All)
Click on Vibrations as shown above. If the phone vibrates, then there is some issue with Settings or Software. Restart or Reset should help you. Of it doesn't vibrates, time to visit the service center.
How to Fix Vibrate not working on my phone
Good Luck :)
Sours- How to Fix Vibrate not working on my phone
Feb 20, 2016 | Samsung Galaxy S6 Edge
No New Email Alert Sound or Vibration
If the sound and vibration work but only for a short time try setting the actual sound vibration settings to a longer setting. Instead of vibrating/beeping for 1-2 times or for a few seconds set it to 4-5 beeps,vibrates. Check the manual for this settings location on the phone.
Jan 13, 2008 | Apple iPhone Smartphone
Water pump replaced plus engine and transmission mounts but now engine sounds rough and steering wheels vibrates while idling
Find an another workshop and have a second opinion.
I never heard about vibrating steering wheel after changing waterpump. That have done something wrong. Probably timing belt is one notch incorrect on one gear. It should be checked and corrected asap. You might damage your valves.
Nov 01, 2017 | Vehicle Parts & Accessories
Have a vibration in the sound quality
Sounds like a bad speaker. Only parts affected are main board and speakers, but more likely that it is the speakers. Does it happen all the time on all sources?
Jan 06, 2014 | Vizio L32 32 in. LCD HDTV
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Severe vibration and knocking sound!
sounds more like a ujoint or a center support for the drive shaft. also check and make sure that the flywheel bolts have not come loose. also check the harmonic balancer and make sure it is not seperating
Aug 23, 2009 | 1996 Ford Explorer
Phone keeps on vibrating
Slide tone (Menu 9.4.5)
Use this menu to select the tone that the phone
sounds when you open or close the phone.
Change this tone (vibrate) to another sound, in the Menu.
Feb 21, 2008 | Samsung SGH-D900 Cellular Phone
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
I can't get my blackjack phone off of vibration
what you do is go to profiles and go to edit then u can change the settings
Oct 29, 2007 | Samsung Blackjack SGH-I607 Smartphone
LG 42LC2D 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
