Question about Canon Cameras
How do you use a remote shutter release for a canon d 50 slr , and where do you find the timer on same camera?
    Novelist:
  • 155 Answers
You need a remote shutter release button attached either via a cable, or wirelessly. Canon make several models, as do many third parties.
As for self timer, press the AF-Drive Button then use the select wheel to move from single shot to high speed, slow speed or self-timer modes.
Posted on Feb 20, 2009
What setting would i use to take a good picture of halloween pumpkins
Shoot on manual with a low shutter speed and mount the camera on a tripod or sturdy surface. if you don't have a shutter release use the self-timer and don't touch the camera during the exposure.
Oct 28, 2014 | Canon EOS Rebel T5i 18-135mm Kit...
Canon EOS Rebel GII With 35-80 Lens 35mm Film Camera shutter
In manual mode you should be able to change the shutter speed simply by turning the main dial (the thumbwheel located near the shutter release button).
Jun 28, 2012 | Canon EOS Rebel G-II 35mm SLR Camera
Camera shuts off after pressing shutter
Manually turn off the camera, remove the batteries, press the shutter release a few times draining any residual charge. Replace the batteries give it a go. It the issue continues it well may be something wrong with the shutter release.
Jun 02, 2011 | Canon EOS Rebel 2000 35mm SLR Camera
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
My shutter release button is not working, instead the shutter is being released when I use the film advance lever.
Your camera has a bad magnet in the body.
Repairs will cost more than probably what you paid for it; I'd suggest getting a replacement (I got a Canon AE-1 Program for $40 on craigslist, ebay has good prices)
Nov 11, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
AE-1 self timmer
The battery is not the problem. It is more likely the the internal switch has failed, (always stuck on self timer). The switch is a ring around the release button for the shutter. The small black tab covers the red LED in normal release mode, the self timer is on when the tab is facing forward.
Jun 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter Lockups on Canon EOS 30 SLR Film camera
Detach the lens and try
Or Shoot at infinite focus, If the camera works then the problem is with your reflex mirror
Jan 27, 2008 | Canon EOS Rebel G 35mm SLR Camera
Cameras Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
