Question about Konica Minolta Office Equipment & Supplies
ERROR CODE C-4401 On Konica Minolta Bizhub 500
Error will not clear, copier will not work. Can access most features on the control pad. New toner cartridge installed after the code appeared - No effect.
  • 26 Answers
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Posted on Feb 21, 2009
F2-40 error code on mx3110n
black toner supply trouble, try a different toner cart, remember to shake the cart before installing. power the machine on and off, if the code is gone then it was the cart if it doesn't clear your service tech needs to see the machine.
Jan 13, 2014 | Sharp "MX-3110N Color Copier, Printer,...
Black cartridge error
First, check to see that a toner cartridge is in fact installed.
Open the toner access panel and remove the cartridge.
Check to see if it is indicating that it is empty. If so, replace the toner cartridge and wait for the error message to clear as the machine prepares the new cartridge for printing.
Dec 20, 2012 | Lexmark X4650 InkJet Printer
I want to clear error code f2 40
Did you just put a new toner in???? The error code means that the toner cartridge is not working correctly. I would take the cartridge out and carefully shake or swing the toner cartridge to loosing up the toner inside the cartridge.... Also, there is a drive gear on the back of the cartridge > try to turn the gear a few times to break the toner up and reinstall & turn the copier OFF then back ON. If that dose not solve the problem > try another cartridge... Good Luck
Nov 01, 2011 | Sharp AR-5320 Black and White Copier
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Aug 03, 2011 | Samsung ML-2851ND Laser Printer
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
    3. Close the lid.
Feb 15, 2011 | Lexmark C534dn Laser Printer
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Nov 03, 2009 | Konica Minolta Magicolor 2450 Printer
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
806 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
