Question about GE DBL333EA Electric Dryer
TIMER WIRE DIAGRAM
I HAVE A GE DRYER WITH TIMER PART #131850900 AND THE WIRES HAVE BEEN TAKEN LOOSE. I NEED TO KNOW HOW THEY GO BACK?
  • Anonymous Feb 22, 2009
    Where does the green wire (maybe it is the ground) connect onto the prongs ?? It came unattached and I need to know where it goes. Thanks!
  • Anonymous Feb 28, 2009
    repair man took timer loose i nedd to know how it goes back
  • GE Master
  • 8,220 Answers
Just attach the green wire to any screw closeby. Nothing could be simpler. Look closely and you will find a small male terminal to connect the green wire in some models.
Posted on May 13, 2009
Timer does not seem to be working on auto
If have a wiring/scematic diagram for the machine and a meter, you might try tracing the problem that way, just a thought may be a loose or bad wire on the back of the timer. It could be possible that the timer may have gone bad. Please let me know if this helps you in anyway.
Mar 21, 2014 | GE DRSR483ED Electric Dryer
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Aug 26, 2012 | GE TIMER PLAS. SHAFT - WE4M366
Wiring diagram sunsmart. I am replaceing a timer swithch of a differnt brand. I have a single pole installation, but the power enters the fixture and then comes to the switch. The diagram in the box...
Sounds like you have the GE sunsmart timer, and are wiring the timer for single-pole.
Following information does not apply to 3-way timer wiring.
Add a comment if you have different timer.
Start with previous timer:
The previous timer was connected to two wires: Hot wire and Load wire.
Hot wire carries power from circuit breaker.
Load wire connects to fan,light, or motor.
How to wire Sunsmart:
1) Only one wire in the electrical box is Hot. That wire is usually black. Connect black Hot wire to timer-black wire.
2) Load wire connects to timer-blue wire.
3) Timer-red wire is capped off for single-pole wiring.
4) Timer-green wire connects to bare copper wire.
5) Timer-white wire connects to Neutral wire. This will power the timer electronics. The previous timer probably had a battery to power timer electronics. Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box.
6) If box does not have Neutral wires, then connect timer-white wire to bare copper ground wire until neutral wire can be run from any nearby outlet box.
7) Try the timer, and if timer does not work, then reverse timer-blue and timer-black.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 01, 2011 | Hardware & Accessories
How do i change my timer
Please make sure that the wiring is not tampered and taken out. Purchase the same type of timer and connect the wires after you have a sketch diagram with the wire codes so that no terminal wiring mistake is done while changing the timer.
Use the colour codes or use wire codes on the wire so that a wrong wiring is not possible.
Mar 11, 2011 | Dryers
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
Wiring are loose in dryer, we need a diagram to connect wires, according to color. please help
The following link explains, in detail, how to correctly wire a power cord to an electric dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Pay particular difference to the 3 and 4-wire configurations. There is a difference in how the neutral and ground wires are terminated. If you have questions, please post back and let me know. I receive email notifications to all your comments and/or questions. I hope this helps you.
Apr 15, 2010 | Amana NDE2335AY Electric Dryer
A couple of wires came loose on the start switch GE Dryer.
If there are only two wires to the button it doesn't matter. The button would make the electrical connection between the two to start the cycle.
Dec 09, 2009 | GE DBSR453EBWW Electric Dryer
Have ge dryer changing from 3 prong power cord to four prong need diagram
The main difference between a 3-wire and 4-wire configuration is how the Neutral and Ground wires are terminated at the temrinal block. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
In a 3-wire configuration Neutral (WHITE) and Ground (GREEN or BARE COPPER) are terminated TOGETHER at the terminal block via a ground strap.
In a 4-wire configuration these two wires are independent of each other are NOT terminated together.
If you have questions, please let me know. I hope this helps you.
Nov 28, 2009 | GE DBXR463EBWW Electric Dryer
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
Broken sensor
In a GE dryer the sensor rods are below the front support and air duct assembly it may be that a wire has come loose or broken. The sensor itself may be bad but I would remove the front panel check wires before purchasing the part.
Dec 31, 2008 | GE DBSR453EBWW Electric Dryer
GE DBL333EA Electric Dryer Logo
404 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
