Question about GE GSH22JFR Side by Side Refrigerator
Door hinge on refrig door
We have a two sided Ge Profile refrigerator the Refrig door use to stop and now it swings open with much effort. How do you fix this?
  • 410 Answers
The door stop on the bottom of your door is either bent or broken off. this si located on the hinge side on the bottom of the door the part number needed to repair it is WR02X11465 you will have to empty and remove the door from the refrig to replace the part. it is a fairly easy do it yourself fix. good luck and thanks for using FixYa Peyton
Posted on Feb 20, 2009
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
. I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
When you open the refrig. the door slams open. I thought there should be a guide to stop that???
There is a small stop to keep it from flding completely back. If the door is swinging back hard the frig is tilted back too far and there is too much heavy items in the door containers.
Eric
Nov 19, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Right side door swings open without stopping.
At the bottom of the door , there is usually a steel piece which keeps the door from opening too far . Sometimes this piece gets bent or the screw holding part of it falls out , letting it move with the door . You should check the bottom of the freezer door and compare the angle and movement to the refrig door . Also , the adjustment for the door could be too hight , causing it to miss the door stop .
Oct 17, 2009 | GE Profile Performance 25.2 cu. ft....
GE Profile Arctica Refrigerator Displays OFF PSS29NGNAWW
Sadly i would say the board is malfunctioning and needs replacement. There is nothing in the fridge/ freezer that if malfunctions can cause that.
Sep 21, 2009 | GE Profile PCF25PGW Side by Side...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Ge profile artica side by side refrig
is it the type of doors with the plastic snap on caps that cover the hinges, if so pop them off and unscrew, if it has an ice maker on the door its more complex, good luck
Mar 13, 2008 | GE Profile PFS22 33" Artica French Door...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
159 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
