Question about Kipor Electrical Supplies
Problem with a kipor 12 ta generator
I have a problem with a shutdown on a kipor 12 ta,it reads L.H propect any ideas what it means cheers
  • 169 Answers
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Some times the starter does not start (it seems like there is no dc volt in the battery))but the battery is OK
Start with the obvious first. Remove and clean your battery terminals and wire connections. Before you reconnect the battery, check your battery voltage across the +/- terminals with a meter. It should read 12 to 12.6 VDC. If it reads less than 11 volts, replace the battery. If the battery is good and the battery connections are clean & tight, you may have a faulty starter or a starter relay.
Jan 14, 2014 | Kipor Generator Diesel Kde5000ta
Kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
I start de generator ahd the light of L.H.propect is on and emergenci stop and off de generator.
check your oil level. many generators have a low oil level light and will shut off to protect the engine
May 30, 2010 | Electrical Supplies
Kipor 6700t - The battery keeps dying on my genny. I changed it today but now it turns over but doesnt kick in. Any ideas? Em
Ff you do not have a draw an the battery.
It is the battery.
Unless you cycle your generator every few weeks this small battery will drop below 12 volts and start destroying it self.
SOLUTION:
Our best fix was to add a 5 watt solar panel and now the battery stays above 12 volts and has extended its service life.
Hope this tip helps.
R/
David
Mar 11, 2010 | Electrical Supplies
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Jun 16, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
1,146 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
Chuck Graybill
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
