Question about EliteGroup 845GV-M3 Motherboard
VGA Adapter stops working after memory install
I have currently 1 256MB DDR400 memory card. I ordered a 1 GB PC3200 DDR 400 and installed it. The screen goes dark right after the windows GUI appears. I tried safe mode and Enable VGA but to no avail. I also trued the new memory card alone with the same results. Do I have the wrong memory or is the memory bad?
  • paul995 Feb 20, 2009
    When I run setup, it only shows four settings, all related to boot up. No settings for memory size or voltage, Does this seem right?
    President:
  • 2,692 Answers
Wrong memory speed.  333 max. 2GB Max
Below taken for you support site (See Link)
MEMORY VGA Adapter stops working after memory install - ecs_buttom_03.gif  2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif  Support DDR333/266 DDR SDRAM
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=465&CategoryID=1&DetailName=Specification&MenuID=45&LanID=9
Posted on Feb 19, 2009
  • Thomas F. Schneider Feb 20, 2009
    Yes. That is correct. THe RAM speed is not ajustable. Your  DDR400 RTAM wil not work. It had a 400 Front Side Buss speed, but only a 333 Ram speed. Go to the website I gave you the link for and download a manual for your model computer motherboard, so you may read all of the particulars yourself.
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
PC3200 (DDR400) DDR SDRAM
Maximum 2GB
Jan 03, 2011 | Biostar P4M80-M4 Motherboard
Whats the biggest and or best cpu i can put into this motherboard. i curently have an amd athlon xp 2800. i just bought some more ram and wold like to know if i can speed up the cpu.
Here is a list of supported CPUs.
http://www.ruby-electronics.com/store_item/MSI_Athlon_XP_Duron_nForce2_Motherboard_K7N2_Delta_MS-6570-020
If you're going to upgrade to the XP3000+ (the fastest supported CPU), then be sure to get the one with the 200 MHz FSB.
Also, go with the lowest supported latency DDR PC3200 you can get IN PAIRS. Remember that Windows XP 32 bit only allows a total memory allocation of 4 GB which must include your video car memory and any memory allocation for add-on cards.
So 6 512MB sticks of DDR PC3200 are better than 2 2GB sticks of DDR PC3200. As the 6 sticks will allow for dual channel transfers (above and beyond the Double Data Rate) and will keep you well within your 4GB limit (once you add the video memory and any add-on cards).
You'll also benefit from doing a fresh install of XP with nlite or similar and stripping XP of all of the components you don't use. Good LUCK!
Oct 13, 2009 | MSI K7N2 Delta-L Socket A/nForce2/FSB...
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Memory Card for MV42N Motherboard
The Shutle MV42N can take SDRam or DDR
Each memory slot can hold DDR PC2700,DDR PC3200,
up to 2 gig total. the pc 2700 is DDR333 and the PC3200 is DDR400. Why Stop at 256?
Mar 18, 2008 | Shuttle MV42N (SHUTMV42N) Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
EliteGroup 845GV-M3 Motherboard Logo
136 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
