Question about Coleman Heating & Cooling
Heat relay in coleman air conditioner not functioning
  • 51 Answers
You have stated the the heat relay is not functioning. If the relay has no voltage when you set the unit to heat then the relay may not be the problem. However if voltage is present and the relay is not working then you are correct that the relay needs to be replaced.
Posted on Feb 19, 2009
Fan will not shut of, air conditioner works fine have to shut down with breaker why ? coleman mach rv rooftop
Either your fan is in the on position or you have a stuck relay or possible short in the wire.
Jul 19, 2017 | Coleman Heating & Cooling
Where can I get a schematic for a Coleman 3500A816 air handler?
With some units you must set thermostat to fan on to get the fan to run in heat mode.. or it could be a bad motor or fan relay . Generally in electric heat units one side of heater is always live then the sequencer turns heater on when thermo calls for heat.
Nov 19, 2014 | Coleman Heating & Cooling
Series 48000 with heat pump we don't want this to run all the time will the heat shut off when it reaches a certain temp also if the power goes out does it come back on automatic we want to heat our place...
Not sure about your particular make and model, but air conditioners are designed to work with a thermostat to control the functions. A properly functioning thermostat will stop the compressor when the set space temperature is satisfied. When the space temperature falls below (heating) the set temperature, the thermostat should turn it back on. In the event of power failure, an electronic thermostat probably will not operate at the previous set temperature when power is restored, but maybe at a higher temperature (but will work).
Dec 05, 2013 | Coleman Mach 15 Air Conditioner
I have a 3 ton Coleman heat and air pump and when I turn the air condition on the heat strip comes on at the same time
If you are calling for heat and the thermostat is set for 2 degrees higher than room temp, the heat pump and strips come on.
When the room temp and stat temp are less than 2 degrees the strips turn off.
That is, unless the installer wired the t-stat for the strips to stay on.
If they are coming on in the air/cool mode then you have a bad heat relay or a t-stat wire shorted.
Mar 11, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
