Question about Refrigerators
I have a Whirlpool Model EC3JHAXRL00. The ice
I have a Whirlpool Model EC3JHAXRL00. The ice maker does not seem to be getting water to make ice cubes. I pulled out the water filter canister. Vacuumed out the lower back after removing the cover. I do not see any ice in the flexible tubing. I unplugged the unit. Plugged it back in. What do you think the problem is?
  • 6,784 Answers
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Posted on Feb 19, 2009
My GE Monagram Ice maker is not making ice. I have cleaned with approved cleaner for the clean cycle and it does not seem to help. The water just seems to flow over the freeze plate and periodically a thin...
I don't have the service manual for this model without having to purchase one but I have a link to Whirlpool Service Manuals which is very much the same when it comes to diagnostics. There are several reasons that may cause this problem as you described. They are water control valve sticking causing warm water to continue to flow over freeze plate and stopping ice production. A defective condenser fan or a very dirty condenser coil. Link to Whirlpool 15 inch and 18 inch Ice Maker Service Manual Link to a site where there are information and answers for most model ice makers HERE You can contact this person at the bottom of the page, Thanks Sea Breeze
Mar 06, 2013 | GE Monogram ZDI15C Automatic Icemaker
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a model GD5PHA whirlpool refrigerator, no ice
the ice maker control the water timing.
if you have voltmeter you can check it on the water valve that go to the ice maker. but you can also disconnect the water from the valve and see if water are coming out.
99% its the ice maker that go bad.
Jan 19, 2010 | Refrigerators
Ice maker does not work
could be your timer isnt working, might check that
Jan 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool icemaker quit
I/M itself is most likely bad. Is there ice in the mold or is it dry?
Nov 28, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side refrigerator
hi there,
the freeze-up is caused by either a kink in the water line or a blocked air vent. check for both.
Nov 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker water overflow
ITS BEST THAT YOU GET A TECHNICIAN TO SOLVE THIS FOR YOU AS ADJUSTING THE WATER FLOW ON THE ICE MAKER CAN BE A BIT TRICKY.GOOD LUCK.MOHAMED
Sep 02, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
